141 - 160 of 260 Posts
Replace ignition switch
I just wanted to say thanks for the instructions and the photos. I was able to replace my ignition switch and it only cost $40. I didn't have any experience working on a car but the instructions and photos were so good, I was able to replace the switch in less than an hour.
I have a 2004 Envoy XUV 4x4 I6. Several lights on the panel came on at the same time and stayed on. Also the blower motor on the HVAC quit working at the same time. The lights on the panel were ABS, Brake, and service 4WD. I was able to diagnose the problem through another post on this forum. The lights went out and the blower starter working after I replaced the switch.
Thanks again, it was an easy cheap fix that would have cost me a bundle at the dealership.
Tip: Be sure the ignition is in the off position and the key is out of the cylinder. Then look at the old switch when you take it out and see how the white gears/teeth are set. You will want to set the gears on the new switch the same. This will save you alot of time trying to set the new gears in the right position.
Thx.
Thank you for the advice on here. I had similar symptoms as others have mentioned. I had my MIL light turn on last week and checked the code was for an O2 sensor I erased it and 2 days later came back on. I didn't check the code, drove it that day with light on and next day drove with it and began to notice sluggish power, but it's been 110 degrees here and driving with the AC on always etc. so yesterday I noticed I would turn key to start it and it hesitated for like a split second no chime, buzz, then start. driving it and it went in limp mode: stabilitrac light on, service engine soon. got it home and it died out, but read 4 codes first P2101, 1682, 1516, 0054,. remembered reading this thread and researched it, changed in 30 minutes. Started fine, runs good. Will keep an eye out for O2 sensor code P0156 if it comes back especially since I'm near 100k miles Thanks again.:thumbsup:
Many thanks to the OP and those that followed with the great advice and pictures. I have a 2004 Ascender with 110K miles, and just recently had the blower/ABS light issue. After finding this thread, I fixed the problem in under 15 minutes. Took longer to check out at NAPA than to fix!
Thanks again to the OP for the thread, and to the moderators for maintaining one of the best forums on the web! :yes:
Cheers,
Brian Clark
Norfolk, VA
key turns fine, everything comes one, but NO TURNOVER/START
I didn't see the PICS in the pages, or in the very first post. But did see the youtube links in the pages in the middle.
My problem with my '03 envoy v8 is not always starting up.
The key turns fine, the accessories are coming on, but it does not turn over or attempt to start the motor. turn the key back n forth several times and then it goes (turnsover and starts strong).
A few years ago the dealer replaced something in the steering wheel, swtich? or the barrell where the key goes, as the tranny flaked out and went into "limp home" mode.
I will look back at theri paperwork tonight no know for sure what they changed.
this has been happening for a few weeks. eventually it starts, sometimes in 2 tries, sometimes in 5 minutes. I thought it was the key and how I position it, but it seems flakier than that.
Is this really the ignition swtich module? intuitively, i woul dhave though it was where the keys goes, not the downline module...
thanks, in advance for help/info and a pointer to the pics.
-todd
follow-up
To follow-up on the other post, in Aug-2005 (@ 48,000 miles) I had the transmission stuck in 3rd gear and the truck ran in "limp home mode " I think it is called. the dealer changed the ignition switch, officially they claimed it was "internally shorted" $32 part 177 labor (wow, ridiculous), i has some other things done at the time too. But the easy-care extened warranty picked it up at that time. the part # on invoive was 12450251.
my symptoms are different this time, but is it the ignition switch module again?
liek some have posted, that one module has a lot of weird affects on the vehicle...
-todd
-todd
ignition swtich (which brand?)
In my previous post, the dealer changed the original out at 48k miles, now at 140,000 miles it seems the OWM part failed again.
which barnd is best from experience here?
The NAPA one?
Echlin ECH KS6254
The Advanced Auto one?
BWD CS643 (this one was referenced on pages 1-2 of this post from Hawaii
The AutoZone one:
Duralast part LS1115
or the one from the dealer, I didn't call for a price yet, but the ones above are 38-44 $ range.. so saving 5 bux for the OWM at dealer may not be worth it if these things fail every 3-5 years.
-todd
Just replaced my switch. The YouTube video was just perfect! A must to watch before doing this. I did mine in under 15 minutes. It took me longer to do the research than to do the job.
One time saver--I did not disconnect the battery. I didn't think it was necessary. Perhaps I was lucky. :undecided
The NAPA one?
Echlin ECH KS6254
The AutoZone one:
-todd
Order the original AC Delco - it's only $13 + shipping from Rockauto.com (or $25 shipped from Amazon)
still having trouble with NEW switch
changed out this weekend the new ignition switch, the new part # with grey side. worked great when I put in, today when my wife was out and about, she had to turn the key five times until it turned over. that was the same symptom as the old ignition switch.
there are no other sypmtoms or warning lights that come on. any ideas of what would cause that beyond the ignition switch? could the key barrell be a problem also?
-todd
ignition swtich not the problem
Changed out the ignition swtich last weekend. the '03 envoy has failed to start easily 3 times since then. after 10-20 turns of the key, it eventually decides to turnover. what would be the next logical thing to check? the ignition lock cylinder or maybe a connector/wire issue somewhere?
thanks for any advice / guidance.
-todd
This was a great tip from chillycole that worked for me.
My TB would not start Wednesday night, and the key was stuck. I was able to get a jump, and limped home. The next day I had my battery tested at O'Reilly's, and they told me it was at 91%, and told me that was good. I took their word for it at the time, since it had just been overworked by me cranking it several times trying to get the truck started the day before. I bought a new ignition switch and had it installed pretty quickly. As chilly mentioned, if you just click until you reach the "first" position (with the indentation), it should easily work when you insert the key from the "off" position. As it turns out, I still needed a new battery after all (had major corrosion - shame on ME), so once I swamped in a new one, my baby was back on the road!
Okay, I replaced my ignition switch yesterday. I was nervous, I had read numerous posts about this, but some of them conflicted, and I wasn’t sure what I was getting myself into. I haven’t done a whole lot of work on newer car systems, although I did replace the stepper motors on my Envoy a while ago. The switch replacement was unbelievably simple, and anyone can do it.
Anyway, I decided to make this post, hopefully it’ll help someone who needs to do this in the future.
(FYI, I have a 2004 Envoy XUV, with foot pedal adjustment and tilt wheel controls on the steering column, and had no problem at all.)
First, you’ll only need two thin regular screwdrivers and the replacement switch to do the job.
Disconnect your negative battery cable. I’ve heard that you should disable the airbag, but I’ve read that others did not do this, and neither did I. Just to be safe, I tried to stay away from the front of the wheel while working on the switch.
Take one of your screwdrivers and gently pry the covers of the steering column off. They should separate pretty easily, then you just need to remove the bottom cover to get access to the switch.
Once the cover is off, you’ll see the bottom of the switch where the harness plugs in, the rest of the switch is slid up into a metal sleeve.
Take your two screwdrivers and insert them into the two holes in the metal sleeve. This pushes back the spring tabs on the ignition switch, allowing you to pull the switch assembly down and out of the metal sleeve. The pictures below have two red arrows showing where the two screwdrivers need to be inserted. The yellow circle shows where the harness connects to the switch. The last picture shows the switch removed from the sleeve, but not disconnected from the harness.
Disconnect the switch from the harness.
Look at the teeth of the old switch and compare them to the new switch. Align the new switch gear with the old switch gear. There is a gap in the gears you should see that greatly helps with the alignment.
Plug the harness into the new switch.
Insert the new switch into the metal sleeve until you hear the spring tabs engage the holes in the sleeve.
Reconnect your column cover.
Reconnect your negative battery terminal.
Start her up.
Hope this helps. Took me about 15-20 minutes to do, and most of that time was spent getting the stupid harness off the old switch.
(Moderators, feel free to relocate this post if necessary.)
I tore into my steering column yesterday to see if there was any loose wire or touching wires. But to my amazement there wasn't any. What I did notice is that on the second picture there is what looks like a cylinder with a piston sticking out underneath. I believe that is th override for the key release. Is that thing suppose to be hot to the touch?:confused:
I changed the switch for the second time in two months. Sunday truck was running great in the morning, came home all is great. Later that day headed out and went to start, turned key and CLICK. Dash lights come on, everything except it won't turn over.
Changed Ignition switch and it started but now No AC or heat will blow thru the four front vents that aim for the head. The vents for the feet and windshield work but not the four vents that are for driver and passenger. when I change
the setting to blow at head it'll send the airflow to windshield and feet.
When I reconnected the negative cable to battery after changing out the switch, it sparked a tiny bit. Could that have shortened whatever controls the front vents to blow? Also when I did start the car I turned the key and for a second nothing then it started right up and the AC came on by itself. ?? I read awhile back that it's not good if AC comes on like that after reconnecting cable to batt... Any ideas... I do have the climate control.
...now No AC or heat will blow thru the four front vents that aim for the head. ...
Classic failure of the HVAC airflow mode actuator after a power removal to the control module in the dash.
http://forums.trailvoy.com/showthread.php?t=40235
Sparks are normal, and not the root cause of the HVAC problem. You might get it to recover with a fuse-pull reset and giving it time for a proper recalibration upon next start-up. All described in that thread.
Ignition Switch??
Every ~25 starting attempts, my Envoy won't turn over. All the lights / accessories come on, but the started won't engage. However, when this occurred I could simply use my remote starter fob, and it would start no problem. After reading the posts here it seemed that I had a classic case of a failed ignition switch. I replaced it with a new switch, and it started initially; but unfortunately I seem to still be having the same problem with the same frequency i.e. not starting every ~25 attempts. The fact that the remote fob works no problem would indicate to me that the starter is fine, but I don't have any other ideas. Suggestions?? I almost wonder if I got a bad replacement ignition switch, but I recognize that this is highly improbable.
