121 - 140 of 260 Posts
That's what I thought it was, the ignition switch. Wow this month alone I've replaced the water pump, fan clutch, alternator, and a battery. Thanks for the reply and will use your how to step. Again thanks:):ugh:
no crank/start
OK gang, I'm new to this forum so I just want to say "Aloha" from the 808 state. I have an 03 Trailblazer LT and have a no crank/start issue. I'm gonna try the ign. switch deal and cross my fingers!!! Thanks for the help!!!:)
tell me one thing.
is it possible to start the vehicle by moving the teeth with your fingers all the way to the left? that would tell me if i have the teeth lined up wrong or if it is something else.
i installed my new switch with the teeth lined up the same as the old one. and turned the key to accessory, dash lights will turn on, then try to start it with no luck. something doesnt feel right with my key now. its like there is a lot of slack in between acc and start.
i can however turn it to acc, and start it with my remote starter.
this is a brand new ignition switch.
reason for installing is i couldnt get the car to start last night and couldnt get the key out of the ignition either. just had to let it sit in acc position all night and let the battery go dead.
Thank you guys, I replaced mine last week and everything has been working great. The pictures were a very helpful guide. There is also a great video how to on youtube which really helped build up my confidence doing this job.
please help
:worried: k I was told I needed a new ignition switch because I couldn't get my truck to start n the key was stuck in the ignition. It will not lock n allow me to get the key out. I (a clueless young mother of 5) with the help of your post n picts was able to easly replace the switch. Unfortunately it didn't fix the problem. Anyone have Any idea what could be wrong?
Sounds more like the ignition lock cylinder, not the electrical switch. Hopefully someone on here can help you out more than I can.
Normal retention tab. Not an evil three-simultaneous-tabs with safety interlocks like some of the airbag connectors.
Hello,
in the middle of replacing ignition switch on 07 tbss read all the info on removing bottom plastic cover but cant get past the tilt and foot pedal levers. Should i remove the steering wheel to get the bottom plastic off? any other suggestions would be a lifesaver! thanks :)
Discussion starter · #133 ·
Hello,
I know you posted this a while ago... probably already figured it out, but on my Envoy, the foot pedal lever didn't need to move, and the tilt wheel lever just pulled straight out. Don't remove your steering wheel!!
...dad my truck isn't starting right??
Here we go......02 envoy xl 160k
Starts with the symptoms of a drained batt. Noise comes from the column right after start and turning it off(whooshing of sort ). she says she gives it some gas and it helps the start ....im not sure if it does??, tb probably needs a cleaning.
I think it's time for a switch?? She also says sometimes it wont start or will on the 2nd or 3rd try.
The batt and alt have been replaced recently also.
any thing else that starts working would be a plus ..think her seat is out and blower too.....no warning lights , reads 14ish on the volt meter.
looks like I have a evening with a envoy:ugh:
Discussion starter · #135 ·
"She also says sometimes it wont start or will on the 2nd or 3rd try."
This, more than anything else you posted, makes it sound like a switch to me. Doubly so after hearing you've already replaced the battery and alternator.
Don't worry, it's a quick fix, and not too expensive.
Switch went easy as pie ,replaced it in 10 min. Sure was a great help being able to read the procedure and ,,with good pics..thanks guys :thumbsup:
But... she still has the hard start like a batt drain at 1st start. After some running it will fire right up.
One thing it did and still does is it will reset the radio clock when it acts up.
Now could the batt loose a cell if the alt went and she ran it? ...did smell batt when I changed the alt. If the batt is not it , my next guess is a short of some sort pulling the batt down over night.
Im leaning to a cooked batt the more I think about it .
Btw the switch was the factory one @160k ..guess that was a good one for as long as it lasted...or is still good .
Ignition switch and low idle stall
I have been having trouble with a common problem, the low idle stall, and my repair shop "thinks" it is in the ignition switch. I have cleaned the throttle body and have had them check the computer upgrades. Thinking of trying this repair. Any thoughts.
Me: 2005 Trailblazer 4.2L 213,000 miles.
