Sorry for not posting sooner. I installed the pair of Pioneer TS-G1643R two-way 30RMS speakers in my Front door panel. The installation was very simple (thanks to another TrailVoy thread with step by step pics). Taking off the door panel can be done in 2 minutes, just be careful with the "sail" snap (upper front), I broke the clip on one of them.
Since I got the speakers from Crutchfield, I followed most of their directions for removing the old speaker. My ONE takeaway is that you should NOT remove the black cloth/mesh from the front of the stock speaker. Don't pull the glue/tape off of it. If you don't leave this on then the new speaker will not have any protection from inside your car, except for the door panel. Not a huge deal, but I quickly learned this on the first speaker I installed. You have to re-use the stock speaker bracket/mount. You can just unscrew the old speaker (without removing the black protection cover) and also punch out the old tweeter and cut the wires. I had to use a drill bit to make the hole bigger in the bracket so that I could run the new wiring through the hole to the new speaker (not a big deal, but it wasn't in the Crutchfield instructions).
The sound is a nice improvement. These are not high-end speakers, but a much better sounding speaker than the junk stock speakers I had. There is quit a bit more base coming from the new front speakers as compared to the rear, I have to lower the base quit a bit on the head unit or else they sound to unbalanced. I am going to get another pair and replace the rear, this should also take care of the different base volumes in the speakers.
The new speakers do sound louder and clearer, but would still like more volume. I can turn my dial all the way up and tolerate the sound. They do start to crack a little when you really crack it.
My next addition is to replace the rear speakers, get a cheap amp and hook it up to my factory head unit. I think the sound quality will improve drastically and it will give me some extra volume. It would be nice to take advantage of the full 30 RMS in these guys.
I am also considering adding Bluetooth phone and audio kit for Trailblazer - Parrot MKi9200. It will take by single CD player away, but who cares, right? I stream all my music anyhow.
http://www.crutchfield.com/s_333MKI9200/Parrot-MKi9200.html?tp=8395
Has anyone used the MKi92000 before?
