(him=yes), I still think one of the 2 relays has a bad connection internally.
Haha, thanks. You may be right about one of the relays, I don't think it's an individual wire.
Will get back with you on your question concerning about if both doors stopped working at the same time.
Thanks again,
Heyken
My reason for asking, is that this could be a problem inside the doors..........but only if it did not happen at the same time.
What I'm trying to say, is it possible that one door stopped working and then (sometime later) the 2nd door stopped.
If that could possibly be the case, we must consider the internal solenoids and the door wiring.
We also must consider a mechanical (rust maybe) problem with the doors.
However, if both doors stopped working together, then the problem is in the relay area.
We could try a relay swap.
Identify the 2 relays we have been talking about (they should be the same), then look around on the fuse board for the same relay.
If you find a match, pull the lock relay and try the 3rd relay and test the locks.
If no change, pull the 3rd relay and reinstall the lock relay.
Repeat above with the unlock relay.
