This is a ongoing saga on our Envoy. It all started about 2 weeks ago, and I have been searching this site for wisdom. I do have a Actron 6000 scantool and have checked and reset these codes as well as pending and dct counts. It's always the same p0171 & p0174. I've checked the gas cap, checked all the vacuum lines, and the block for the xtra dipstick hole. Everything seems fine. It will go a couple day's no problem's and then set a code again. I can freeze frame when it happen's and seems to log the fault around 165deg 174deg range. I do have a idle miss ever since I changed plugs last year. Logged from cyl 1 and 2 that seems to mostly clear up when hot. I'm at a loss and thinkin the next step is to take to the steelership. So we hope we get some help from you helpful folks... BTW clock is reading 42,000 miles
