1 - 13 of 13 Posts
This stuff is bad. coated on my dads rims in the front. Washing with a brush did absolutely nothing. I've tried a a couple of different cleaners from walmart, but I am clueless as to what to do to get this stuff off.
Family is going to their house for 4th of july and i want to clean his rims since he just can't do that kind of thing anymore.
Wheel are aluminum, no clear-coat. Any thoughts on what to do?? I From what he says it sounds like they haven't been cleaned in a couple years.
Will post before and after pics after the forth if I can get some ideas on what to try!!! Please help.
So I could use the Mothers mag and aluminum polish? that's gonna take the brake dust off?
Just making sure I get the right stuff. :undecided
polish is for polishing, not cleaning, you would be doing more harm than good
find the correct cleaner, get it to a good base then go from there
but if you are talking years of no cleaning, you might be talking damaging the rims before they come clean and might need to be refinished
Discussion Starter #5
and the correct cleaner would be?? sorry I just don't know what to get.
:duh::duh:
Meguires has 2 types of wheel cleaner. Both available at wally world. They work well...just make sure you read the label and get the right one.
Matt
Lots of brake dust cleaners that work well,
Go to a auto parts store and ask for ,Or tell them what you need to remove brake dust.And I would not get the one's with acid in first . They can stain your wheels with white marks if left on to long ,,, And the only reason I said to use steel wool is because you said they have no clear coat and they would not come clean . Dont use it if just spraying cleaner on works .and after ,You will probably have to use the mag or aluminum polish to bring the shine back, That's if they dont have clear coat or paint on.
If that doesn't work get the one with acid in ,And the finest steel wool you can ,But you well have to use mag polish then . it takes some elbow grease then, to bring back to a shine. If not clear coated.
2007 chevy trailblazer_ss_3ss
Get meguires all wheel wheel cleaner not :Dchrome.Its in a red spray bottle and costs around 6 bucks.spray it on leave on for 2 min and wash off. Also smells like cherry.
2006 chevy trailblazer_ss_ls
Stoner's Tarminator and Sonax Wheel Cleaner. They Work Very Well
gmc envoy_sle
WD40 works. Don't just spay on brake caliper. Don't scrub with harsh rough steel wool or a scour pad.
I spray WD40 on a washcloth/ol shirt & go around rim, go to next tire. By then return to starting tire & see if it's grime/brake dust is loose.
If need be, use brush/steel wool/scour pad that won't scrape/gouge your rims, especially if they're chrome.
If you have a day off all to yourself, remove your tires & get at them. WD40, tire cleaner, degreaser, ajax, baking soda+WD40, wash rinse (repeat if not satisfied) & dry then wax.
Hope this helps. We we bought our envoy, i ran into the same thing. Once a month i WD40 the oem rims.
1 - 13 of 13 Posts
