I have a 2007 TB with a 4.2L. I recently had the engine rebuilt over the summer due to the previous owner locked up the motor. The new rebuild was a totally different long block. Kept existing PCM.
The issue.....When the car has sat for numerous hours in cold weather below 40 degrees outside it will not start and idle. It turns over great, has ignition and will run for 2-3 seconds, stumble and dies. I have to try and start it 3-5 times until it will catch and idle without dying. It is totally outside temp related. Once the engine is warm regardless of outside temp it runs great.
When the outside temp is above about 40 degrees it runs and idles fine.
I have run Sea Foam through the tank, no change.
I have replaced plugs, no change.
I have no codes.
Today I let it sit cold, put on a fuel pressure gauge on and read 60 psi while starting and maintained 60 when dying.
I have good compression.
The emissions air pump seems to kick on at start. I can hear it. Maybe could check line?
I have read maybe need to have EMC data updated to new sensors? IDK
One fella mentioned soft code for Throttle body Ice?
Maybe mass air flow sensor? IDK
I am at a loss. Any ideas? Hard part tacking to a good tech is it only does it when cold outside and after sitting for hours.
I have no codes.
