Hi guys, i tried searching for a while but havent come up with anything. I just bought a set of kc slimlite 130 watt driving lights for my westin safari bar and i was wondering how i should run them...Either i was going to install the switch that came in the kit or set them to go on either with my lows or highs. Any recommendations?
all of my lights are separately controlled.. gives better access to each situation that u need the lights for... if u plan on only using them (since u said the driving lights) when there is no other traffic around then u could wire them to the highs...but personally i would wire them up to a separate switch that way u choose when to turn them on... cause if u wire them to the highs... then when u hit the high beams or flash someone... u are gunna get a lag down in the engine from the sudden rush of electricity needed to turn on all 4 of those lights... i mean that would be what over 350 watts turned on all of a sudden pulling around 30 amps...
i'm not saying, i'm just saying... :m2:
and if u need references check out my gallery ;) lol
