sounds like they are dried out.. I would look for some Bosch units.. I have the Revolutions on mine currently
You may want to try cleaning the blades. Mine were hopping a good bit after I had done 3 weekends in a row of off road. Wiping down the blades seems to have helped as a short term fix, but I'll probably need new wipers soon. I've had a good experience with RainX wipers.Anyone ever have your wipers "chatter" as they go down? They go up fine, and if you have full power to them, but if they are on an intermidiate setting the chatter or studder on the way down?
I'm def. gonna have to try this. It's making me nuts lately. I just read how to get at everything in the Chiltons.Its not the blades- The contact wheel inside the gearbox is covered with grease, and caused intermittant contact, which causes the stutter. I cleaned mine after reading about this here 3 years ago, and its been fine ever since.
Remove wiper motor assbly, and take cover off of gear houseing. You will see a wheel that is covered in grease- wipe the surface clean and reassemble. Pretty easy free fix. You might spend some time putzing to make sure wiper linkage is aligned if you don't mark it before you start.
FKNA drolds, you saved me 75 bucks.Its not the blades- The contact wheel inside the gearbox is covered with grease, and caused intermittant contact, which causes the stutter. I cleaned mine after reading about this here 3 years ago, and its been fine ever since.
Hey man, on a side note about your issue, If it is indeed not mechanical. I used to have the rainX wiper blades on my old Saturn. I too treated the windshield with rainX untill one day I was reading the instructions and either the wiperblade packaging or the rainX bottle said not to combine the windshield treatment and the wiperblades on the same vehicle because both were silicone based and could cause chattering...Same issue here but only on the drivers side. I don't remember having the issue when I had my last blades on there. I replaced the old one's a few months back with the Rainx brand. I also use Rainx wiper wash and occasionally apply the RainX stuff to the windshield. I thought maybe it was too dry on the way back down. It drives me NUTS though! I tried swapping the left to the right but that didn't help either.
