1 - 10 of 10 Posts
2006 gmc envoy_slt_xl
Hey Y'all.
Recently bought my wife an '06 Envoy XL with a 4.2 L and 3.42 rear end(GU6 code).
I drive an F-350.
After reading numerous threads I have learned alot from everyone...Thank You!
I still have a bit of concern...we seem to be at the limit with our camper and want to ensure we're safe.
Camper (fleetwood pop-up) is 3800lbs, dry w/ electric brakes and we have a WD hitch.
The owner's manual (Envoy) says we're good to 5000lb. (about where we'll end up fully loaded).
Through everyone's advice and experiences we're looking at the following.
adding:
Tranny cooler, on the outlet side. (AutoZone B&M)
p3 brake controller (found one for $100 in san antonio)
So.....
Will this set-up be sufficient for long trips i.e. TX to Fl and back in the heat of the summer????
If I have overlooked anything, please advise.
Thanks in advance
pj
South Chapter
2008
I would think so. I'm sure some others will chime in on this one. I tow a flatbed with mine, and have had no issues even while towing my S-10, but mine is the 5.3L V8 with 3.73 gears.
BTW, Welcome to TrailVoy!!!!! Enjoy your Ride!!!!:thumbsup:
you will be fine with those mods and the fact that it is flat terrain is a plus. also may want to consider running synthetic oil. helps keep the engine cool. i have 3.42 gears and i tow my pop-up without a problem.
many thanks....
BTW, been using mobile 1 since it first came out. swap out immediately after every vehicle I buy (except my f350). have put more than 3 million miles on various vehicle without a single engine complaint.
I noticed that Mobile 1 also has tranny fluid...any feedback???
Thanks again...wouldn't want a good trip to go bad.
pj
i use royal purple everything they have tranny fluid, coolant additive, gear oil and thier oil is wonderful i love the stuff myself maybe check that stuff out if you want something real good
:iagree:same here i use royal purple in all my vehicles.
1 - 10 of 10 Posts
