1 - 6 of 6 Posts
Ok so I have one run of 0/1 gauge from my batt, I will be adding my kinetik 2400 battery and there is not enough room to run 2 runs of 0/1 under my carpet so I was going to just run my power wire from my batt up front to the kinetik and then just ground my amp to the kinetik and ground the batt to the frame will this work okay?
Thanks, Dan
i know someone with 3 runs under the carpet, i have 2 myself:cool:
I ran mine under the door sills and that was a tight fit I could run it under the seat or something but I dont want big humps in the carpet from my wire. So I was just wondering if I could run the single and just ground the batt in the back to the chassis?
there is like an 1.5 inch pad under the carpet i just cut out a path in the pad and there is no bump seen in the carpet
1 - 6 of 6 Posts
