Northeast Chapter
2004
Yes. I have 255/75/17 on mine. However, you'd be hard pressed to fit that tire back on the truck without some rubbing issues unless you lift it.
2004 chevy trailblazer_ls_ext
Will it fit?
Yes they will definitely fit. But you will probably need to grind a little for a safe amount of clearance. I just had 255/70/17 firestone detination at's mounted on mine and i do not have wheel spacers. But there was only 1/8" clearance up top so after i put the grinder to the upper control arm there is a good 1/2 to 3/4 inch of clearance. Oh and they fill the wheel wells nicely.:D
