I know I posted this before, then ran out. I found some more and am offering them again.
Here's what you'll get:
2 connectors that allow you to connect the temp sensor wiring to the stock wiring harness in the engine compartment.
2 rubber plugs to "seal" the connections.
This does NOT include the sensor or wiring. These are just the small metal connectors that go on the wires to click into the wiring harness.
If you need them, Please e-mail me at [email protected] and I will get a set out to you, free of charge.
Thank you!
Discussion Starter #2
Update
Update:
I am out of the rubber plugs (mine was installed without them and has been fine ever since) but I still have some connectors left if you need them. Just PM or e-mail me.
For reference, I got them from Mouser Industries.
Connector:
GM P/N 12191818 - Delphi Female 150 Series TIN
Mouser part # 829-12191818
Rubber seal:
GM P/N 15366021 - Delphi Loose Cable Seal
Mouser part # 829-15366021
You need to buy in bulk from Mouser to make it worthwhile, which is how I has some available.
If they are out of #829-12191818, part #829-12191819 will also work for the connector.
