1 - 7 of 7 Posts
2003 chevy trailblazer_ltz
Just a little information about my car: '03 TB LTZ 64,00 miles. I recently replaced the spark plugs and fuel filter. When I started the car, there's a semi-loud whistling sound coming from the oil dipstick. When I lift the oil dipstick an inch or so, the whistling sound goes away. But when I push the dipstick down all the way, the whistling sound comes back.
Any ideas what could be wrong??
Thanks in advance.
when u pull the dip stick up can u feel any vacuum or air pressure going in or out of the tube?
Not sure. When I get off work tonight, I'll double check.
When you replaced the plugs did you put the hoses etc. back on the intake pipes?
yea check all the hoses and see if u can feel any airflow from the 710 tube... sounds like u got a vac leak or something...
:iagree: Take the dipstick out and cover the hole with your finger or a vacuum gauge. You should feel suction. :m2:
Discussion Starter #7
I'll double check all the hoses, etc. tonight. Hopefully it's just something minor. Thanks again.
1 - 7 of 7 Posts
