1 - 3 of 3 Posts
2005 gmc envoy_slt_xl
Recently my 2005 Envoy XL (68k miles) developed intermittent whine thru the rear door speakers only. It is a Bose system with DVD, XM. It has this whine thru those 2 speakers only; it does it no matter what source DVD XM AM FM or CD. You can also fade the speakers to the front and noise is still in those speakers. If you shut the truck off, remove key and open door the noise MAY disappear. It just starts the noise randomly, I have tried turning on every accessory in the vehicle to make it start and I can’t make it start the noise once gone
Anybody have any experience with this or a solution? :undecided
Discussion Starter · #2 ·
I may have solved it myself, now to call the dealer
#PIT3522E: Buzz Noise From Rear Speakers After Bulletin 04-08-44-014B - keywords AMP amplifier door radio rear sound speaker UQA - (Jan 9, 2008)
Subject: Buzz Noise From Rear Speakers After Bulletin 04-08-44-014B
Models: 2004-2007 Buick Rainier
2004-2007 Chevrolet TrailBlazer, TrailBlazer EXT, Trailblazer SS
2004-2007 GMC Envoy, Envoy XL, Envoy XUV and Envoy Denali
2004 Oldsmobile Bravada
2005-2007 Saab 97x
This PI was superceded to advise that bulletin 04-08-44-014B listed in this PI applies to 2004-2005 vehicles only. Please discard PIT3522D.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Rear speaker noise on vehicles with rear seat audio controls (RSA) and Bose amplifier. This noise can be produced from a variety of high load or PWM controlled electrical components (rear window defroster, heated seats...) but usually can be identified as an whine noise related to engine speed (generator electrical feedback). This condition can be verified by turning the RSA on (rear speakers off) and the noise should go away. If the noise is the same the root cause most likely exists elsewhere and additional diagnosis is necessary.
Recommendation/Instructions:
Perform the following procedure to reduce the rear speaker buzz noise AFTER all low level and high level circuit integrity has been verified. For example, it is possible for the system to produce audio output to the speakers even if a (-) circuit has an open. However it will most likely produce undesirable noise in this condition.
Note: Bulletin 04-08-44-014B applies to 2004-2005 vehicles only. The Transfer Case Control Module ground has been relocted on all 2006 and newer vehicles. The information may be helpful on 2006 and newer vehicles.
Important: Prior to moving forward with the directions below, all 2008 model schematic refer to all connectors as the letter "X" then the connector number. The letter X is the new global term for connector. Since this PI address 2008 and prior, the connector number will be written both with the letter C and the letter X.
Note: After each step below, re-evaluate the concern. If the concern is repaired, there is no need to continue with additional steps.
A. Check for damaged harness under the passenger rear 2nd row seat. This step applies to short wheel base vehicles ONLY equipped with AMP RPO UQA.
Remove the passenger side second row seat.
Remove right rear sill plate
Lift carpet and follow body harness as it travels along the passenger rear second row seat toward the amplifier.
Repair any damaged wires and reroute the harness to prevent future concerns.
B. Remove the AMP connector. On short wheel base vehicles, the AMP is located behind the right rear 1/4 trim panel. Removal of the trim is needed to access the AMP. On extended wheel base vehicles, the AMP is located on the left rear 1/4 trim panel. Remove the access panel in the left rear trim and locate the AMP connector.
Remove the C1 or X1 AMP connector.
disconnect and pin drag terminals B3 B4 B5 B6 and B12. Use test probe J-35616-6 (BN). Replace any loose or damaged terminals as needed.
Reinstall the AMP connector and evaluate.
C. Inspect the Bare Wires for terminal Integrity.
Remove the radio and the C1 or X1 connector.
- Check terminal tension on C1 or X1 terminal A5. Use test probe J-35616-6 (BN). Replace any loose or damaged terminals as needed.
Remove the AMP connector C1 or X1 and C2 or X2
- Check terminal tension on C1 or X1 terminal B12. Use test probe J-35616-6 (BN). Replace any loose or damaged terminals as needed.
- Check terminal tension on C2 or X2 terminal E. Use test probe J-35616-6 (BN). Replace any loose or damaged terminals as needed.
D. Remove the center console assembly from the vehicle. Refer to the Console Replacement procedure in the Instrument Panel and Console sub-section of the service manual.
Locate the C307 or X307 connector to the left of the transmission tunnel. The driver's seat may also need to be removed in order to gain access.
Inspect the connector and see if it is fully seated. Secure connection as needed.
Unplug the connection and pin drag B1 B2 B5 and B6. Use test probe J-35616-4A (PU). Replace any loose or damaged terminals as needed.
E. Locate the C304 or X304 connector. This is located under the second row rear seat on the driver's side. There is a cut out in the carpet were this connector can be accessed.
Inspect the connector and be sure it is fully seated.
Disconnect the connector and pin drag terminals D3 D6 D7 and C12. Use test probe J-35616-2A (GY). Replace any loose or damaged terminals as needed.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed
I am having a very similar problem in my 06 TrailBlazer. I noticed it before I installed any aftermarket equipment so I believe it is a stock issue. I replaced the Bose 6 disc with a F90BT from Pioneer. I get a whine coming only from the driver's side rear door speaker. I can notice an increase in pitch as I accelerate. The volume can be turned off and I still hear a whine. The speaker also clicks whenever the brake pedal is touched or the turn signal is on. The whine comes and goes, sometimes whining on start, sometimes just randomly while driving and sometimes can be stopped by tapping on the brake pedal. It seems to be connected to the harness on the brake pedal because when messing with the wires, it will click in the speaker and click in the housing for the gear shift.
Has anyone tried the Recommendation from the Bulletin?
Where was the problem for you?
I hear a click in the Transmission Housing, so I may start with option D.
Tired of just turning up volume to fix the problem...
1 - 3 of 3 Posts
