1 - 8 of 8 Posts
2006 saab 9_7x
Hi all,
Can anyone tell me which transfer case my SAAB 97x 5.3 has? It is fulltime AWD. I am hoping it is the same Torsen as is used in the TBSS. So, Anyone have the answer?
Thank you,
NTRSANDMANN
I'm about 99% certain the 5.3L uses the same unit as the Rainier & Bravada did, basically a version of the standard unit with the Lo range removed to allow for a larger clutch pack and programmed/pre-wired to permanently run in A4WD mode. Now the Aero, with the 6.0L does in fact use the same drivetrain as the SS.
2006 saab 9_7x
IT appears the AWD TC in TBSS and Saabs is
a New Venture 120. (maybe also referred to as NR9)
but my research is limited. if anyone knows better, they can chime in.
Best regards
2006 saab 9_7x
so a little more news, the NP or NVG , or whom ever owns them now. WOTN number is the 136, 1 for single speed, 3 for strength rating, and 6 for electronic locking.
there was a couple of sites that lead me to consider a 149
single range, stronger, viscous coupling, but I tend to agree with the above poster that, for the 5.3i, it's the same as the Rainier's, which was a NV 136 (RPO code NP4)
it would make sense that the NP149, is what ended up on the SS and Aero, as it has a Higher strength rating. But I don't know that to be the case, I consider it a possibility.
Now the process to uncover whether a 4hi lock is possible with a little electronic work and a nice switch.
(such as was possible with the Troopers BorgWarner TOD systems)
have a good one
2009 chevy
The AWD trucks use a NVG (New Venture Gear) 126 case,
The 4x4 trucks use the NVG 226 case
The SS trucks have a completely different case.
Northwest Chapter
True and true, but the SS has the EXACT same case with different guts.
Nothing shares the Torsen T-3 AWD setup the SS has except the Saab 9-7X Aero. Anyone that has a Torsen xfer case in a non-SS/Aero has swapped it.
1 - 8 of 8 Posts
