1 - 7 of 7 Posts
http://www.performanceplustire.com/...3/productID/5094/wheelDataID/41644#prodAnchor
Bolt Pattern: 6x127
Finish: Polished
Manufacturer Part Number:
Backspacing is 4.5"
offset 0mm
i want to get these wheels, but the person i talked to when i went to order them said they wouldnt fit without a 6" lift. which is pretty much impossable
i would assume that they would because it would be the same as having spacers, and i have a 2" lift, so i would have pretty much the same set up as alot of other people that it has worked for.
i am going to go ahead and order them soon so i was wondering if anyone else had any input.
ya, i am going with a bigger tire also, 255/70/17 or 265/70/17, i just wanted to make sure i wasnt over looking something because he said theres no way they would fit without a 6" lift, which makes no sense, because they are in our bolt pattern.
Northeast Chapter
2004
Rims you chose will fit just fine.....tire size you are talking about is what I have in my garage, sitting beside my lift kit, and new suspension components. So, you might read this prior to getting tires for it....
http://forums.trailvoy.com/showthread.php?t=33809
Rims will look nice though. Good luck!
.. the person i talked to when i went to order them said they wouldnt fit without a 6" lift. ...
You're right. That offset is equivalent to having 2" wheel spacers.
And without a discussion of the tire size, the person who required you to have a 6" lift is a useless goof. The collected wisdom of Trailvoy is 100 times better than any tire store clown. But you knew that. :thumbsup:
1 - 7 of 7 Posts
