1 - 7 of 7 Posts
Just bought a 2004 for my daily commute... and cant stand the stock wheels..LOL
What offset should I be looking at if Im stepping up to a set of 20's or 22's
2007 gmc envoy_denali
Hope this helps a little!
To my knowledge, trailblazers and envoys have the same offset, which is unique and not used by another GM vehicle (told so by a GM employee). which would be 6x125 but don't go buying rims without looking into that. Good luck!:thumbsup:
Actually, it is 6 x 127 mm which equals 6 x 5 in bolt pattern. Most Chevy trucks are 6 x 5.5 in. bolt pattern.
Gene:)
2006 gmc envoy_denali
offset Rim Spec's
You gave the bolt pattern but that's not the offset.
Envoy Denali Wheel specifics
Factory OEM
Rim Diameter: 18" Manufacturer Part Number: 9595872
Rim Width: 8" Quantity: 4
Offset: 50mm (1.968498 ") Bolt Pattern: 127mm (4.999985")
Finish: Polished Number of Bolts: 6
1 - 7 of 7 Posts
