What should i get?
2373 Views 18 Replies 9 Participants Last post by  Opeio
Hello everyone finally started on my system I installed the pioneer AVH-P4100DVD head unit with bluetooth and onstar/steeringwheel controls and now im to the part where i know nothing about XD
What type of subs should i get and amp/ do i need anything else to go with these to make sure that its legit.
Im looking to get 2-3 12's and plan on just having a regular box in the back nothing super custom or anything. I just want to be able to remove the box incase i need the cargo space
Also i want to get a set of tweeters in my A pillars just dont know what brands are good and give the best sound.
I plan on getting these installed by a professional just because i dont know anything about wiring up subs and amps.
So my budget is roughly around 1000$ for the subs and amp and tweeters if anyone would help point me in the right direction or help me with a set up that will sound good, and any suggestions for the box so i can relay to the dudes making it :D
1 - 19 of 19 Posts
You not gonna replace the factory door speakers?
Well i dont think they sound bad right now especially since i added the new headunit. Do you recommend i replace them?
are you going for loudness or sound quality? if you get a mutli channel amp you can power the sub and some nice aftermarket speakers
I almost always replace factory speakers. I agree, they don't sound bad but wait until you replace them with some quality aftermarket one's.
You'll be like :duh: why did I wait.
wait till you see the massive magnets on the OEMs:laugh:
:crackup::crackup::crackup::crackup::crackup::crackup::crackup:
Well Im trying to have a good balance im thinking ill go for quality over loudness. I figure 2 12's will be pretty loud even if they are quality. : )
Well i guess since you say so ill do it :D So if you had 1000-1200$ to buy tweeters subs amp and speakers what would you spend them on? Thats kind of what im looking for :D
yes, replace 'em.
if your having it installed and buying off the internet, the installer WILL charge you more.
$1000 .... you wanna buy used? dealer? internet?
The title of your post is "What Should I Get"... So with this being said, your HU was a good start. Your looking at getting 2-3 12" subs while leaving the factory in your doors and dash. More than likely you will be very dissatisfied with the sound (subs will devour your OEM speakers). How about this setup instead,
replace your doors & dash with coaxials
put tweeters in your a pillars like you want
get a beefy 4 channel amp (75x4)
1 15" in the right enclosure with the proper power can sound comparable to 2 12"s
1 mono block sub amp (800x1)
a 3 farad capacitor
Everything should run you like in the neighborhood of about $1300 at Ikesound.com (internet).
yes, replace 'em.
If you gonna buy your own equip and have someone else install, you are going to get charged more than usual. Most installers don't like this because the only money they make is in the labor.
You may want to look into going to your local audio store and asking them what they have and how much the whole package would be. You may get a rather good deal especially with how the economy is right now.
a 3 farad capacitor
1. get components.
2. 2x 12's will have more surface area, therefor be louder. and with a smaller cone, be more accurate.
3. no cap, if anything a small battery like a kenitic hc600 or 800
dont forget you still need a multiamp power kit
does the 1000 include install?
no the install is on a seperate budget : ) im just talking equipment here... willing to pay from 1000-1300 i just want as nice a set up as possible with a clean loud sound.
id say find a friend that can help ya with the install so you can afford a higher quality system. shoot theres enough help here to get you through the easier stuff.
Yeah i installed the head unit with my friend, its just i want everything to look professional and dont wanna mess anything up with the amount of money im putting into it :D As i said i know literally nothing about amps or subs or speakers for the most part
Thanks for the ideas and the 4 channel is better the the single channel correct?
the "one" channel or mono block is for the sub, and the 4 channel is for the sub or subs
I have the same HU installed in my '03 TB.
The next step I took was to replace the stock speakers with after market units, I chose a matched pair of 6.5" Kenwoods and for now left the dash Tweeter in place. I am using the HU to power those speakers.
Next plan is to run the wiring for our Kenwood amp that we already have mounted on the back of our Dual 10" box. I found it loaded with MTX speakers from Crutchfield.
Costs:
HU: $410 Amazon
Door Speakers: $50 per pair, wiring adapters included Crutchfield
MTX 10" subs and Box: $225, Crutchfield
Kenwood Amp: $220, Sears
Amp Wiring: $100, Local stereo shop.
Replacing the door speakers was very easy, the Pioneer HU has a nice built in Mosfet PS that will work to keep cost down for now.
Take a look at some other folks installs to see the best way to keep the wiring clean, do yourself a favor, install it yourself, that way, if there is a problem, you have an idea how to fix it and not have to take it back to have the shop find the problem. Amp wiring can be very simple or very difficult depending on how many amps and what add on's you install.
You can also flush mount a remote USB cable and 1/8" stereo cable next to the aux power supplies for Ipod/MP3 use as well.
Best thing, the pride in knowing you did it yourself or with the help of a friend.
Costs:
HU: $410 Amazon
Thanks for the ideas man and everyone saying to do it myself is making me want to XD i might wait until my friend gets back though so ill have some help and another head incase something confuses me! I still may get my box custom made because i dont have the tools or anything to build one of those and make it sound good :D
1 - 19 of 19 Posts
