1 - 3 of 3 Posts
Hello all, I'm new to the forums and would like to say hi.
I have a 2005 Trailblazer LS with the I6 4.2L and it has 4WD and AWD on the instrument panel.
So I jacked it up put it on stands and removed the rear brakes and realized the backing plates are rusted and wasted. So I decided to drop the rear differential cover so I could remove the pin from the spider gears and pull the C-clips to get the rear axles out. When I drop the rear cover there was a setup I have never seen before.
I have never seen this type of rear differential configuration. And I used to rebuild these back in the late 80's when there was just simple lockers and posi-traction. Does anyone know how to properly remove this so I can get the axles out?
I tried to post a photo or a link but see that I'm too new. If anyone can help I'd be glad to text it or email it.
Discussion Starter #2
OK I identified this as a Eaton G80 Differential. I have to get a 6 point 5/16 wrench tomorrow so I can remove the Spider Gear pin without stripping the head of the bolt. Going to replace the axle seals and the backing plates once I get this apart and hopefully before the weekend. I'll let you know how it turns out.
Thanks for all your help this has got to be one of the best websites ever. I have never gotten this much help with any other issue. Keep up the good work.....
1 - 3 of 3 Posts
