That's the CV side of your crankcase ventilation system.
You NEED that replaced if it's missing. If you want ont put it back, your crankcase will build up moisture, won't evacuate blowby and generally allow crankcase vapors to escape into the air.
FUN FACT ----> Crankcase vapor controls were first installed on military vehicles to burn these byproducts to add to fuel mileage. Yup! True fact!
2008 gmc envoy_sle
make sure that hose is good, check for clogs, cracks or breaks, follow its routing. its an important part of the engine. allows the crankcase to breathe/vent properly,
2005 chevy trailblazer_lt_ext
Discussion Starter #4
The hose is right there, it just wasn't on the proper place. It just came back from the shop and I was getting drops in rpms and rough idle.
Sent from my SM-G960U1 using Tapatalk
Discussion Starter #5
The hose is good and is right there, it just wasn't on the proper place. It just came back from the shop and I was getting drops in rpms and rough idle, so I checked the engine and saw that this little hose was not connected.
I had no idea what this hose was, but it was obvious it should be connected right there
