1 - 6 of 6 Posts
02 Oldsmobile Bravada, 235,000 miles, vortec 4.2L
Hi I have a summer driver 02 Bravada. To make it RWD, I was told to take out the ATC and 4WD fuses. What does each of them do?
Since the Bravada is an AWD vehicle, it does not have a 4WD fuse. In a full 4x4 vehicle (Trailblazer or Envoy) that fuse powers the front disconnect actuator. The ATC fuse powers the TCCM (Transfer Case Control Module) and encoder motor brake.
Discussion Starter #4
Would pulling out the ATC fuse have the same effect as disconnecting the encoder motor?
With the ATC fuse out, the TCCM will be dead and not front drive will be engaged. Just be aware that the some of the internals of the transfer case will still be moving as you drive, so it might be advisable to make sure its fluid is at correct level and clean.
Discussion Starter #6
My Bravada has both ATC and AWD fuses. I took both of them out and strangely the "Service AWD" didn't even come on. ¯\(ツ)
54700
54701
1 - 6 of 6 Posts
