I am having problems with my washer fluid on the passenger side. The fluid works on the driver side and the rear windshield, but doesn't come out at all on the passenger side. Any suggestions on how to fix this??? It does not appear clogged...so I'm thinking the problem is underneath the hood. I am trying to have my dad fix it instead of taking it to the dealership so any help would be appreciated!
Thanks!
2006 gmc envoy_sle
What year do you have? Might be a frozen or kinked line. You have to get the wiper arm assembly if your nozzles are on the arm
envoyguy
I have a 2006. The nozzle is not on the arm. It is on a plastic piece right between my windshield and my hood.
Pop open the hood and have someone hit the washer switch and look at that plastic block, it may be cracked and spraying out under the hood. I had that happen on my old silverado. The drivers side stream was also a little weak due to no backpressure from the passenger side. Once I replaced the block they both worked like a champ.
