1 - 10 of 10 Posts
Does anybody know where to locate the vss wire on an 04 Envoy w/o bose, nav, and onstar?
The vehicle speed signal is the DK GRN/WHT wire into pin B9 of the instrument cluster.
If you've got the 5.3L engine, it's also available at pin C12 of the engine-to-IP harness 38-way inline connector located on the back side of the underhood fuse block.
If you've got the rear air compressor, it's also in pin A3 of the chassis-to-IP harness 38-way inline connector located on the right side of the underhood fuse block.
Thanks for your help
2006 chevy
Would any of these work for an 06' SS as well? I would like to keep it inside the firewall, so would the instrument cluster one you mention be referring to the actual harness plugging into the cluster? Thanks
What wiring adapter are you using?
I used a METRA. After calling their tech support, I found out that it provides a VSS source wire.
And a note to add to this, it will function without the VSS wire but seems a bit jumpy.
After you add the wire it disables some functions when going over 5mph. I got around this by adding a switch between the instrument cluster and the radio. Now when I want to change my destination when moving I flip the switch, then I flip it back when I am done.
Since I don’t think the 2006 TB LS has the VSS wire already at the radio harness, if I spice the VSS wire from the instrument cluster which pin does it go to on the GM navigation console?
Hope this helps..
Tachometer WHITE (AC) IN BLUE PLUG ON PASSENGER SIDE OF ENGINE
Speed Sense VIOLET/WHITE (AC) IN HARNESS ON PASSENGER SIDE OF ENGINE COMPARTMENT:thumbsup:
2008 chevy trailblazer_ls
2008 vss
i'm trying to find the vss wire in the dash for my 2008 L6 trailblazer, i'm installing a pionner nav system and need the signal from the vss.
1 - 10 of 10 Posts
