1981 - 2000 of 2032 Posts
2006 saab 9_7x
Hi 07TB,
I've been going through a lot of your VIN number requests. I have a SAAB 9-7x and some of the RPOs that I have are not listed. Would like to know what they are. If you get a chance, could you run my VIN?
5S3ET13S862803310
Thank You
Its not a trailblazer, but could you run this VIN for my wifes 2012 Chevy Cruze?
1G1PF5SCXC7146959
I appreciate the look up!
Steve
VIN: 1G1PF5SCXC7146959 Model: 1PX69-2012 CRUZE LT 4 DOOR SEDAN
vin has 1 open recall
Vehicle Build
Model: 1PX69-2012 CRUZE LT 4 DOOR SEDAN Order Number: PTKTTZ
Gross Vehicle Weight: 1,855 Build Date: 08/25/2011
Build Plant: 7
Option Codes
01S - TRIM COLOR SEAT 1AR - TRIM COLOR DOOR PANEL
1LT - 1LT PACKAGE 1SZ - DISCOUNT OPTION PACKAGE
4AA - INTERIOR TRIM A51 - FRONT BUCKET SEATS
A64 - SEAT RR SPLIT, FOLDING, 40/60 A69 - RSTRNT ST-BELT TNSNR, FRT, VAR2
AED - POWER WINDOW, PASS EXPRESS DOWN AEQ - POWER WINDOW,RRDRS EXPRESS DOWN
AFC - MEDIUM TITANIUM AG6 - SEAT ADJUSTER, PASSENGER, 6 WAY MANUAL
AH3 - SEAT ADJUSTER, DRIVER, 6 WAY MANUAL AHN - RESTRAINT PROVISIONS LATCH
AJC - RSTRNT HEAD, FR SEAT,UP/DN ADJ AKK - WINDSHIELD STYLE ACOUSTIC PVB
AKP - WINDOW TYPE SOLAR ABSORBING WINDSHIELD TYPE TINTED AKX - WINDOW TYPE SOLAR ABSORBING
AU3 - LOCK CONTROL SIDE DR, ELEC AWO - RSTRNT SYS RR STBLT,RR,3PNT CTR
AXG - WINDOW PWR OPER-XPRSS DR UP/DN AXJ - PASSENGER CAR
AYF - AIRBAGS, DRIVER & FRONT PASSENGER FRONTAL KNEE SIDE IMPACT & HEAD CURTAIN; REAR OUTBOARD PASSENGERS SIDE IMPACT & HEAD CURTAIN B34 - FLOOR MATS
B35 - FLOOR MATS, REAR B76 - CLUSTER COLOR INST, BLACK
BAH - EQP SECURITY SYS,IMMOB,STEP TWO BS1 - ACOUSTIC INSULATION PKG
C49 - DEFOGGER RR WINDOW, ELECTRIC C67 - AIR CONDITIONING
C91 - LAMP INTR, ROOF, COURTESY C95 - LAMP INTR,ROOF,CRTSY & 2 RDNG
D31 - MIRROR, MANUAL INSIDE RR VIEW D75 - HANDLE O/S DOOR BODY COLOR
DA1 - ARM REST RR SEAT, STORAGE DBU - CNSLE FRT CMPT,FLR,ARM RST SLDN
DLV - VISORS, DRIVER/ FRT PASSENGER W/ VANITY MIRRORS DP6 - MIRROR PROV HOUSING PAINTED
DWY - OUTSIDE MIRRORS, POWER ADJUSTABLE E17 - BUMPER 2.5 MPH
E3E - HANDLE O/S, L/GATE, R/CMPT,CHRM EA2 - POCKET FRONT SEAT BACK, RH
EBJ - TRIM SEAT CLOTH EF7 - COUNTRY CODE, U.S.A. AMERICA (USA)
FCU - TRIM DOOR LEATHER FHO - VEHICLE FUEL GASOLINE E10
FX3 - STABILITRAK - STABILITY CONTROL SYSTEM W/ TRACTION CONTROL FXH - AXLE, 3.53 FINAL DRIVE RATIO
GLF - ICE BLUE METALLIC GNA - CHASSIS EQUIP FRONT STRUT ASM
GNG - SUSPENSION, REAR ENHANCED J93 - BRAKES, FRONT DISC/REAR DRUM
JJ2 - BRAKE LINING BRAKE NOISE & DUST PERFORMANCE K09 - ALTERNATOR, 120 AMPS
K34 - CRUISE CONTROL KC7 - RECEPTACLE ELECTRICAL, RR SEAT
KCL - HEATER DUCT KTA - USB AUDIO INTERFACE
KTF - PRIMARY KEY LHD - LEFT HAND DRIVE
LOD - PLANT CODE LORDSTOWN, OH, USA LUJ - ENGINE, 1.4L ECOTEC VVT DOHC 4 CYL TURBO
MAH - NORTH AMERICAN MKT MDC - MOLDING B/S UPPER BRIGHT
MH8 - TRANSMISSION, 6 SPD AUTOMATIC MM1 - MERCHANDISED TRANS AUTO EQUIP
N34 - LEATHER WRAP STEERING WHEEL N37 - STEER COLUMN TILT, TELESCOPING
NE1 - 50-STATE EMISSIONS NJ1 - STEER PWR, NON-VAR RATIO, ELECT
NU5 - EMISSION SYS CALIFORNIA, BIN 4 QYW - TIRES, ALL SEASON BLACKWALL
R9N - CONTROL-SALES ITEM NO. 89 RU5 - TIRE, COMPACT SPARE & WHEEL (REPLACES TIRE SEALANT AND INFLATOR KIT)
SLM - SALES PROCESSING STOCK ORDERS T3W - LAMP SYSTEM DAYTIME RUNNING, REDUCED INTENSITY LOW BEAM
T4A - HEADLAMPS HALOGEN T74 - HEADLAMPS CONTROL AUTO, DELAY
T83 - HEADLAMPS CONTROL AUTO ON-OFF TM7 - BATTERY, RUNDOWN PROTECTION
TPV - GRILLE RDTR, BLACK,W/CHROME BAR TS6 - LAMP STOP, HIGH LEVEL
TTX - RADIO EQUIP AUX CONN (LINE IN) TU2 - LAMP MARKER, SIDE
U07 - HORN FANFARE U25 - LAMP INTR, RR COMPT, COURTESY
U2K - XM RADIO - SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUS/XM AFTER 3 MONTHS U91 - ANTENNA SHORT, ROOF, RADIO
UAG - INFOTAINMENT DISPLAY GRAPHIC INFO DISPLAY (GID), VAR 1 UD0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT RH/CHILD PRESENCE DETECTOR
UDC - DISPLAY INSTRUMENT DRIVER INFO ENHANCED (ONE COLOR GRAPHIC) UE1 - 6 MTHS ONSTAR DIRECTIONS & CONNECTIONS WITH AUTOMATIC CRASH RESPONSE AND TURN-BY- TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE)
UH0 - INDICATOR SEAT BELT WARNING, LH UH1 - INDICATOR SEAT BELT WARNING, RH
UJ2 - INDICATOR ENGINE OIL LIFE UJM - TIRE PRESSURE MONITOR
ULS - LOCK CONTROL STEERING COLUMN UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER
UPF - BLUETOOTH FOR PHONE UTJ - THEFT DETERRENT ELECTRICAL, UNAUTHORIZED ENTRY
UYE - AM/FM STEREO, CD PLAYER UZ6 - AUDIO SYSTEM, 6 SPEAKER
V48 - COOLANT ENG MAXIMUM PROTECTION V8D - VEHICLE STATEMENT US
VHY - PROTECTOR BODY SHEET METAL, HIGH CORROSION PREVENTIVE VRG - VALUE ADDED ASM COCKPIT
VRH - VALUE ADDED ASM STEERING COLUMN VRK - VALUE ADDED ASM ROOF TRIM
VRL - VALUE ADDED ASM FRNT HORIZONTAL SUSPENSION VRM - VALUE ADDED ASM FRNT VERTICAL SUSPENSION
VRN - VALUE ADDED ASM REAR SUSPENSION VRR - VALUE ADDED ASM TIRES & WHEELS
VTW - GLOVEBOX, AUXILIARY VWC - PANEL CTR INSTRUMENT
VY7 - LEATHER TRIMMED SHIFT LEVER W1Y - STEERING WHEEL CONTROLS
WGA - COLLECTION RDO EQUIP RECEIVING UNIT, RADIO WR6 - WHEELS, 16" MACHINE FACED ALLOY
XL7 - FREQ RATING 315 MHZ, LONG DIST Y67 - DISPLAY REMINDER PACKAGE
Z54 - MODEL CONVERSION LT ZAD - TIRE SPARE T115/70R16 SL 92M BW
Hi 07TB,
5S3ET13S862803310
Thank You
I don't have access for Saab. Sorry. Do any of the rpo codes appear in any of the other vins shown in this thread?
2006 saab 9_7x
Thanks for trying. A lot of the RPO codes do show up on the lists that you have provided for others, but a dozen or so do not. I did not go through all the lists, probably only 20% or so. Between google and other forums I think I have got most of them, but until I can access a Saab database, who knows?
My first post and of course a few questions
Just bought a used 2006 TB that has an LS designation on the body. Now here comes the question, with the upgrades it has and what I have found on here and the WIKI it should be labeled an LT. Example, 4 wheel disc, leather seating with driver power seat, outside heated remote mirrors. Also can someone please run the VIN and let me know some history on it and build info.
Thanks in advance :thx,
Trkrjohn
VIN: 1GNDT13S762220641
build specs / options
07TB, you're a godsend! Can I please have the build specs / options for my newly acquired '04 TB?
1GNDT13SX42374614
2003 gmc envoy_slt_xl
VIN Info
Hi 07TB, I was wondering if you could possibly run this VIN for me. It's for a 1998 Chevy K1500 that I recently bought. Trying to get as much info as I can on it. The VIN is 1GCEK19W3WE226686. Thank you in advance, very much appreciated.
2003 Trailblazer VIN Request
Hi, I have bought a 2003 trailblazer 2 weeks ago. Would love to see what my VIN is showing. Thanks in advance.
VIN - 1GNDT13S632135253
Trkrjohn
VIN: 1GNDT13S762220641 Model: CT15506-2006 TRAILBLAZER 4WD
Vehicle Build
Model: CT15506-2006 TRAILBLAZER 4WD Order Number: JQJB4R
Gross Vehicle Weight: 2,611 Build Date: 11/21/2005
Build Plant: 2
Option Codes
1SB - LS PREFERRED EQUIPMENT GROUP 2 * POWER OSRV MIRRORS * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS * BODYSIDE MOLDINGS * LUGGAGE RACK CROSS BARS * TRAILER WIRING CONNECTOR * REMOTE KEYLESS ENTRY * THEFT DETERRENT SYSTEM 1SZ - PREFERRED EQUIPMENT SAVINGS
28H - LIGHT GRAY 28I - INT TRIM LT GRAY/DK GRAY
49U - BORDEAUX RED METALLIC 6HN - SPRING
7HN - SPRING 8NS - SUSPENSION
9NR - SUSPENSION AJ1 - TINTED GLASS
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG AL0 - SENSOR INF RESTR, CHILD DETECT
AM9 - SPLIT FOLDING REAR SEAT BACK AR9 - FRT BUCKET SEAT, DELUXE
AU0 - KEYLESS REMOTE DOOR LOCK AXP - MPV VIN IDENT POSITION
B30 - CARPETING, COLOR-KEYED B32 - FLOOR MATS, FRONT AND REAR
B33 - REAR COLOR KEYED FLOOR MATS B86 - MOLDING B/S COLOR
B8W - GM PRODUCTION WEEK #47 C49 - REAR WINDOW DEFOGGER
C5N - GVW RATING - 5750 LBS CJ3 - CLIMATE CONTROL
DAY - ASSEMBLY PLANT MORAINE, OHIO DP2 - POWER OSRV MIRRORS
DT4 - ASHTRAY AND LIGHTER EVA - EVAP EMISSION REQUIREMENT
FE9 - FEDERAL EMISSIONS FLT - FLEET PROCESSING OPTION
GU6 - REAR AXLE 3.42 RATIO JF8 - BRAKE VAC POWER, 4 WHL DISC
JJB - PT DRESS SUBASSY NOT INSTALLED K18 - ELECTRIC AIR INJECTION SYSTEM
K34 - CRUISE CONTROL KCV - ALAMO RENT A CAR
KG4 - GENERATOR 150 AMP LL8 - VORTEC 4200 SFI I6
M30 - 4-SPD AUTO TRANS W/OVERDRIVE AND ELECTRONIC CONTROL N40 - POWER STEERING
NP8 - 2-SPEED ACTIVE TRANSFER CASE NT7 - EMISSION SYS FED - TIER 2
NZ3 - WHEEL, FULL SIZE SPARE PDC - SEAT, 8-WAY POWER DRIVER
QC3 - ALUMINUM WHEELS QNF - P235/75R16 ALS BW TIRES
R6F - IDENTIFY B CODE USERS R6P - PREMIUM PAINT
R7M - ONSTAR SERVICE NOT INCLUDED R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
T61 - DAYTIME RUNNING LIGHTS T98 - STAMPING VEHICLE IDENT NUMBER
TB4 - LIFTGATE TFD - RETAIL AMENITY DELETE
U73 - FIXED MAST ANTENNA UA6 - THEFT DETERRENT ALARM SYSTEM
UB0 - AM/FM STEREO W/CD UY7 - TRAILER WIRING HARNESS
V1K - LUGGAGE RACK CROSS-BARS V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VN9 - DAILY RENTAL REPURCHASE PROGRAM VP6 - NOISE CONTROL
VXS - COMPLETE VEHICLE LABEL X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING YT1 - DAILY RENTAL FLAT RATE DEPREC.
ZW7 - PREMIUM RIDE SUSPENSION
1GNDT13SX42374614
VIN: 1GNDT13SX42374614 Model: CT15506-2004 TRAILBLAZER 4WD
Vehicle Build
Model: CT15506-2004 TRAILBLAZER 4WD Order Number: HDKB9M
Gross Vehicle Weight: 2,611 Build Date: 04/05/2004
Build Plant: 2
Option Codes
1SD - LT PREFERRED EQUIPMENT GROUP 1 OPTION PACKAGE 04 1SZ - PREFERRED EQUIPMENT SAVINGS
62U - DK GRAY MET/SILVERSTONE MET DARK GRAY METALLIC 6HP - COMPONENT SUSPENSION
7HP - COMPONENT SUSPENSION 8EW - COMP RR LH COMPUTER SEL SUSP
95H - MEDIUM PEWTER 95I - MED PEWTER/DK PEWTER INT TRIM
9EU - COMP RR RH COMPUTER SEL SUSP AJ1 - DEEP TINTED GLASS
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG AM9 - SPLIT FOLDING REAR SEAT BACK
AR9 - FRT BUCKET SEAT, DELUXE AU0 - REMOTE KEYLESS ENTRY KEYLESS REMOTE DOOR LOCK
AXP - MPV VIN IDENT POSITION B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FLOOR MATS, FRONT AND REAR FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
B42 - REVERSIBLE CARPET/VINYL CARGO UTILITY MAT C49 - ELEC REAR WINDOW DEFOGGER ELECTRIC REAR WINDOW DEFOGGER
C5N - GVW RATING - 5750 LBS CJ2 - AUTOMATIC CLIMATE CONTROL
DAY - ASSEMBLY PLANT MORAINE OHIO DD7 - ISRV MIRROR W/COMPASS
DH2 - LIGHTED LH & RH VISOR MIRRORS LIGHTED LH & RH VISOR MIRRORS DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER
DK7 - ROOF CONSOLE AND TRAVEL NOTE INTERIOR CUSTOM ROOF CONSOLE DT4 - ASHTRAY AND LIGHTER ASHTRAY AND CIGARETTE LIGHTER
EVA - EVAP EMISSION REQUIREMENT GU6 - REAR AXLE 3.42 RATIO
JF8 - BRAKE VAC POWER, 4 WHL DISC JJB - PT DRESS SUBASSY NOT INSTALLED
K18 - ELECTRIC AIR INJECTION SYSTEM K34 - CRUISE CONTROL ELECTRONIC SPEED CONTROL WITH RESUME SPEED
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL N40 - POWER STEERING
N75 - 17" SPORT ALUMINUM WHEELS N79 - FULL SIZE SPARE
NP8 - 2-SPEED ACTIVE TRANSFER CASE NU1 - EMISSION, CALIFORNIA LEV2
PDF - LT PACKAGE 1 * LEATHER WRAPPED STEERING WHL W/AUDIO CONTROLS * RR SEAT RADIO & HVAC CONTROLS * DRIVER INFORMATION CENTER * AUTO CLIMATE CONTROL * ELECTROCHROMIC ISRV MIRROR * ONSTAR SYSTEM INCLUDES 1 YEAR SAFE & SOUND QTR - P245/65R17 FOUR ON/OFF ROAD WOL TIRES - EXCLUDES SPARE
R6B - PROC CODE, ONSTAR NOT FORCED ORWAID IDENTIFIER SLM - STOCK ORDERS
STW - LEATHER WRAPPED STEERING WHEEL T61 - DAYTIME RUNNING LIGHTS
T96 - FRONT FOG LAMPS T98 - STAMPING VEHICLE IDENT NUMBER
TB4 - LIFTGATE TGA - LANGUAGE CONTROL ENG, FR, SPAN
U68 - DRIVER INFO CENTER DISPLAY U73 - FIXED MAST ANTENNA
UA6 - THEFT DETERRENT ALARM SYSTEM UB0 - AM/FM STEREO W/CD
UE1 - VEHICLE COMMUNICATIONS PKG: ONSTAR SYSTEM INCLUDES 1 YEAR SAFE & SOUND, CUSTOM O/H CONSOLE W/TRAVEL NOTE RECORDER, HOMELINK, & ELECTROCHROMIC ISRV MIRROR ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND UG1 - HOMELINK
UK6 - REAR SEAT RADIO & HVAC CONTROLS RADIO CONTROLS RR ST & EARPHONE UPC - TRAVEL NOTE
UY7 - TRAILER WIRING HARNESS HD 7-LEAD TRAIL. WIRING HARNESS V1K - LUGGAGE RACK CROSS-BARS
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA V76 - TOW HOOKS RECOVERY HOOKS
VG8 - NOTICE TO BUYER LABEL VK3 - FRONT LICENSE PLATE BRACKET FRONT LICENSE PLATE MOUNT
VP6 - NOISE CONTROL VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION YA7 - CALIF. ASSY. LINE EMISSION TEST
YC5 - LT DECOR EXTERIOR APPEARANCE PACKAGE YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
YF5 - 50-STATE EMISSIONS ZQ3 - DRIVER CONVENIENCE PACKAGE: DRVR MESSAGE CNTR, AUTO CLIMATE CONTROL, RR SEAT RADIO AND HVAC CTRLS. LEATHER STRG WHL W/CONTL TILT WHEEL & SPEED CONTROL
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID PAINT
VIN: 1GCEK19W3WE226686 Model: -
Vehicle Build
Model: - Order Number:
Gross Vehicle Weight: 0 Build Date: N/A
Build Plant:
Option Codes
Vehicle has no current record of option codes.
VIN: 1GNDT13S632135253 Model: CT15506-2003 TRAILBLAZER 4WD
Vehicle Build
Model: CT15506-2003 TRAILBLAZER 4WD Order Number: FNJD3J
Gross Vehicle Weight: 2,611 Build Date: 08/20/2002
Build Plant: 2
Option Codes
1SC - LS PREFERRED EQUIPMENT GROUP 3 * POWER HEATED MIRRORS * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS W/DEEP TINT REAR * CRUISE CONTROL * BODY SIDE MOLDING * LUGGAGE RACK CROSS-BARS * LEATHER WRAPPED STEERING WHL * THEFT DETERRENT SYSTEM * REMOTE KEYLESS ENTRY 41U - ONYX BLACK/SANDALWOOD MET
6SJ - COMP FRT LH COMPUTER SEL SUSP 7SH - COMP FRT RH COMPUTER SEL SUSP
8EW - COMP RR LH COMPUTER SEL SUSP 95D - MED PEWTER/DK PEWTER ACCENTS
95I - MED PEWTER/DK PEWTER INT TRIM 9EU - COMP RR RH COMPUTER SEL SUSP
A50 - FRONT RECLINING BUCKET SEATS WITH FLOOR CONSOLE AJ1 - DEEP TINTED GLASS W/DEEP TINT REAR
AJ7 - DR/PASS FRT & SIDE AIRBAGS AM9 - SPLIT FOLDING REAR SEAT BACK
AU0 - REMOTE KEYLESS ENTRY (INCLUDES THEFT DETERRENT SYSTEM) AXP - MPV VIN IDENT POSITION
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B84 - BODY SIDE MOLDINGS
C49 - ELECTRIC REAR WINDOW DEFOGGER C5N - GVW RATING - 5750 LBS
CJ3 - CLIMATE CONTROL DAY - ASSEMBLY PLANT MORAINE, OHIO
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER EVA - EVAP EMISSION REQUIREMENT
K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED KG4 - GENERATOR 150 AMP
LL8 - VORTEC 4200 SFI I6 M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
N40 - POWER STEERING NC1 - CALIFORNIA EMISSIONS LEV
NG1 - 50-STATE EMISSIONS NP5 - LEATHER WRAPPED STEERING WHEEL
NZ3 - FULL SIZE SPARE QC4 - 16" ALUMINUM WHEEL
QRE - P245/70R16 BW ALL SEASON TIRES SLM - STOCK ORDERS
TB4 - LIFTGATE U73 - FIXED MAST ANTENNA
UA6 - THEFT DETERRENT ALARM SYSTEM UN0 - AM/FM STEREO W/CD PLAYER
V76 - TOW HOOKS VK3 - FRONT LICENSE PLATE MOUNT
YD6 - BASE REAR SPRING ZW7 - PREMIUM RIDE SUSPENSION
ZY1 - SOLID PAINT
Same info is available from Chevrolet, if you get a customer care person who is helpful to you.
800 222 1020.
P.S. Going through Chevrolet is beneficial because you can tie your name, address etc., to your VIN at Chevrolet headquarters.
In the event of any TrailBlazer info or recalls, you will be notified, from Chevrolet, being that your name is tied to the V.I.N.
Just purchased this one - what have I got myself into? :)
1GNDT13S042291404
VIN: 1GNDT13S042291404 Model: CT15506-2004 TRAILBLAZER 4WD
Vehicle Build
Model: CT15506-2004 TRAILBLAZER 4WD Order Number: GWDG16
Gross Vehicle Weight: 2,611 Build Date: 01/08/2004
Build Plant: 2
Option Codes
1SB - LS PREFERRED EQUIPMENT GROUP 2 * POWER MIRRORS, HEATED * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS * CRUISE CONTROL * BODY SIDE MOLDING * TOW HOOKS * LUGGAGE RACK CROSS-BARS * TRAILER WIRING CONNECTOR * REMOTE KEYLESS ENTRY * THEFT DETERRENT SYSTEM OPTION PACKAGE 02 1SZ - PREFERRED EQUIPMENT SAVINGS
50U - SUMMIT WHITE//DK GRAY METALLIC SUMMIT WHITE 6CC - COMP FRT LH COMPUTER SEL SUSP
7CC - COMP FRT RH COMPUTER SEL SUSP 8EW - COMP RR LH COMPUTER SEL SUSP
9EU - COMP RR RH COMPUTER SEL SUSP A50 - FRONT RECLINING BUCKET SEATS WITH FLOOR CONSOLE
AJ1 - DEEP TINTED GLASS AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG
AM9 - SPLIT FOLDING REAR SEAT BACK AU0 - REMOTE KEYLESS ENTRY KEYLESS REMOTE DOOR LOCK
B84 - BODY SIDE MOLDINGS BODY SIDE MOLDINGS C49 - ELEC REAR WINDOW DEFOGGER ELECTRIC REAR WINDOW DEFOGGER
DAY - ASSEMBLY PLANT MORAINE OHIO DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER
EVA - EVAP EMISSION REQUIREMENT FE9 - 50-STATE EMISSIONS FEDERAL EMISSIONS
GT4 - REAR AXLE - 3.73 RATIO JF8 - BRAKE VAC POWER, 4 WHL DISC
K34 - CRUISE CONTROL ELECTRONIC SPEED CONTROL WITH RESUME SPEED KG4 - GENERATOR 150 AMP
N40 - POWER STEERING NP8 - 2-SPEED ACTIVE TRANSFER CASE
NT7 - EMISSION SYS FED - TIER 2 NZ3 - FULL SIZE SPARE
QC3 - ALUMINUM WHEELS QRF - P245/70R16 FOUR ALL-SEASON WOL TIRES - EXCLUDES SPARE
VK3 - FRONT LICENSE PLATE BRACKET FRONT LICENSE PLATE MOUNT VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
1GNET16SX56173810
Thanks!
VIN: 1GNET16SX56173810 Model: CT15806-2005 TRAILBLAZER EXT 4WD
Vehicle Build
Model: CT15806-2005 TRAILBLAZER EXT 4WD Order Number: HWSS4Z
Gross Vehicle Weight: 2,906 Build Date: 02/14/2005
Build Plant: 6
Option Codes
16U - GRAYSTONE METALLIC 1SB - LS PREFERRED EQUIPMENT GROUP 2 * POWER MIRRORS, HEATED * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * BODY SIDE MOLDING * TOW HOOKS * LUGGAGE RACK CROSS BARS * TRAILER WIRING CONNECTOR * REMOTE KEYLESS ENTRY * THEFT DETERRENT SYSTEM
1SZ - PREFERRED EQUIPMENT SAVINGS 28H - LIGHT GRAY
28I - INT TRIM LT GRAY/DK GRAY 6HD - SPRING
7HC - FRONT SPRING 8HU - COMP RR RH COMPUTER SEL SUSP
9HU - COMP RR RH COMPUTER SEL SUSP AJ1 - DEEP TINTED GLASS
AM7 - FOLDING REAR SEAT AM9 - SPLIT FOLDING REAR SEAT BACK
AR9 - FRT BUCKET SEAT, DELUXE AU0 - KEYLESS REMOTE DOOR LOCK
AXP - MPV VIN IDENT POSITION B30 - CARPETING, COLOR-KEYED
B32 - FLOOR MATS, FRONT AND REAR B33 - REAR COLOR KEYED FLOOR MATS
B84 - BODY SIDE MOLDINGS C49 - REAR WINDOW DEFOGGER
C7H - 6,400 LB GVW RATING CJ3 - CLIMATE CONTROL
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER DT4 - ASHTRAY AND LIGHTER
G80 - LOCKING DIFFERENTIAL GT4 - REAR AXLE - 3.73 RATIO
K34 - CRUISE CONTROL KG4 - GENERATOR 150 AMP
N40 - POWER STEERING N74 - 17" BRIGHT ALUMINUM WHEELS
N79 - FULL SIZE SPARE NP8 - 2-SPEED ACTIVE TRANSFER CASE
NT8 - EMISSIONS, FED TIER 2A OKL - PLANT - OKLAHOMA CITY
PCK - ONSTAR PLUS PACKAGE * ONSTAR SYSTEM-INCLUDES 1 YEAR SAFE & SOUND * CRUISE CONTROL PCR - SUN, SOUND, AND ENTERTAINMENT PACKAGE * POWER SUNROOF * BOSE PREMIUM SOUND SYSTEM * XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT. SERVICE FEE EXTRA 1ST 3MO INC * AM/FM STEREO W/6 DISC CHANGER (REPLACES STD/OPT PKG RADIO)
PDC - SEAT, 8-WAY POWER DRIVER QTR - P245/65R17 FOUR ON/OFF ROAD WOL TIRES
R7C - V8 POWER PLAY PKG. NOT DESIRED R7E - INTERIM PRICE DECREASE
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
T61 - DAYTIME RUNNING LIGHTS T96 - FRONT FOG LAMPS
T98 - STAMPING VEHICLE IDENT NUMBER TB4 - LIFTGATE
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT. SERVICE FEE EXTRA.1ST 3MOS.INCL U42 - REAR SEAT ENTERTAINMENT SYSTEM (REPLACES OPT PKG SUNROOF)
UC6 - AM/FM RADIO,RDS,6 DISC CHANGER, (REPLACES STD/OPT PKG RADIO) UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND
UQA - BOSE PREMIUM SOUND SYSTEM UY7 - TRAILER WIRING HARNESS
V76 - TOW HOOKS VFF - VIDEO FORMAT REGION 1 NTSC
VK3 - LICENSE PLATE FRAME, FRONT VXS - COMPLETE VEHICLE LABEL
