Verify all fuses, especially those for brakes and ABS.Had a dead battery after truck was sitting too long and had to get a jump start. Since then the ABS and the Brake (( ! )) indicator is on. Any thoughts? Any likely connection between the two?
Define "nothing".Nothing from the scanner.
Thanks for the follow up .⬆⬆⬆⬆
Not sure what all that's supposed to mean, but whatever. It was the ground under the driver side. The mechanic/welder who did the chassis work moved the wire but it had come unclipped. Had it reinstalled today at no charge. Everything back to normal...
...aside from the discovery of a leaking oil pressure switch... oh well... at least it's a quick fix.
I means I was going to bed and those are the sounds I make in doing so.⬆⬆⬆⬆Not sure what all that's supposed to mean, but whatever.
