1 - 11 of 11 Posts
2003 chevy trailblazer_ltz
my both rear turn bulbs are fine, but when turn signals are on, they just gloom- and cause hazard speed flashing on all other turn signals.
has anybody found any solution to this; or is it just go thru all fuseboxes and measure wiring thru the vehicle???
and i have been driving my TB for over 20k miles- and it has altogether way over 130k miles on odo. - no major repairs done, just TLC maintenance... reason for writing is temps, its 20F - cold as Finland(=Alaska) winter...no temptation jump around car out there.
yes! solution found; mine was the flasher unit under the instrument panel.
for others having same problem;
1. check underhood fusebox fuse, and rear seat fusebox fuse(s)- a fuse for each turn signal!
2. check the bulbs (remove tail lights- eaazy with 2 screws- and check also the bulb holder thingy- mine were reneeed couple years ago- and my turn signals ”gloomed” so i knew they got some power there...
3. remove the instrument panel lowest panel(2 eazy screws)- you see the flasher unit- press tiny dot that is same color as the tabs of the flasher; it jumps out (mine did atleast)
4.replace flasher- cost like 20 USD- although when sent overseas and all the import tax shoot to support our sweeet wellfare-semisocialism; 50USD or so....
5. have a beer and
enjoy turning signals disco! Hood Automotive tire Vehicle Automotive lighting Automotive design
Automotive tire Motor vehicle Vehicle Bumper Automotive design
Wood Gesture Finger Grey Thumb
Well it was great for a while; now same symptoms only difference is that the rear turns dont flash any faster pace, so all seems fine...; what keeps messing my flasher???
Turn signals just gloom-really dim but when hazard flasher is pressed on, both work???
Discussion Starter · #6 · (Edited)
So where should i start checking the grounds.... changing flasher dont help any more. Still both my rear turn signals just gloom in very dim way.
All other turn signals work in standard pace.
The turn signal problem on my 2004 TrailBlazer was due to defective circuit boards in the tail light housings. Have you checked yours as suggested by EnvoyBoy2004 2 months ago? Replacement boards are available from rockauto.com for about $15.00 each.
  • Like
Reactions: Ravalli Surfer
I have multiple circuit boards, that I KNOW for fact are working, tried and changed them and same symptoms;
when hazard is used, all turn signals function properly; but when normal turn signal is used; the REAR tail lights just slightly "gloom" and sort of try to blink, but very very dim.
Thanks for letting us know!
  • Like
Reactions: impala67
1 - 11 of 11 Posts
