When i am drivin down the road both traction control lights come on for no reason. Anyone know why?
2008 gmc envoy_slt
We could use a bit more info here....does this happen every time it is driven? In order to correctly diagnose the problem let me tell you, you WILL need to have codes read....unless you're a super mechanic, and then you probably wouldn't be asking the question here.
I have had this problem....three separate times....three different sensors replaced, all within 600 miles! I wish I knew why these traction control sensors experience failure. I drive like an old lady...(because I AM one!) Hope this helps.:)
its not every time its really random. when the light is on i do still have traction control.
You will most likely have to pay a dealer to talk to your brake control system with their scan tool to search for saved codes. If you drive too much after one of the incidents, stored archived codes evaporate and age out of memory.
Intermittents are the worst sort of problems to have, unless you catch them in the act. Wish I could tell you it was a loose connector pin in location 42 of C319, but that's impossible, even for the great Carnac.
