where is the spot to fill up the transmission fluid? need help asap. thanks
The more important question is why does it need transmission fluid!where is the spot to fill up the transmission fluid? need help asap. thanks
thanks very muchyes.. use a funnel and use Dexron 6 tranny fluid
Lost the manualI heartily recommend spending an hour or two with the Owner's Manual, that contains all sorts of critical data like this. You'll enjoy a much longer and rewarding relationship with your vehicle if you know what's in the manual. Did I mention it's all laid out in the manual? :yes:
But it's your lucky day you found trailvoy.com, since we have PDF replacements under the "Resources" pull-down menu. No excuses now! :tiphatLost the manual![]()
