To replace the rear (trans connection) lines, dropping the rear crossmember on the trans is supposed to make it easier to get to.
One of my lines wrapped in heat resistant material, right next to the cat con, rotted last month and started to leak. I had a friend of the family who owns a trans shop splice in a piece for me (metal with compression fittings NOT rubber line). Inspecting the rest of my trans cooler lines, the pieces that snap into the fan shroud up front are both rotted and probably next to start leaking.
A call to my local GMC Dealership revealed each piece (4 total) is about $25-$31/each.
