1 - 20 of 20 Posts
Going to be changing my tranny filter soon, just wondering if any one knows about how much has to be added after the filter change. I have a deep pan. Looks like it might hold quite a bit. I have 4 quarts of amsoil but wondering if im going to need more? :undecided
I think it is 5. What does your manual say? If you do not have one you can download one by clicking on the resources button at the top .
gmc envoy_slt_xl
my manual says 4 quarts, and i have a 06 trailblazer swb and 2wd. i just flushed my tranny at 50,000 miles. did it myself. trick to getting all of old oil out is undo the cooler line from radiator and run trailblazer in neutral and you will pump out the rest of the dirty oil that is still in the converter and that amounts to between 2 and 3 more quarts, but don't forget to put filter, gasket and 4 quarts of new oil in 1st before doing the cooler line trick.
complete flush and fill is around 13 quarts
A pan drop and filter change is around 5 quarts for deep pan and 4 to 4 1/2 for shallow pan.
2007 gmc
:thumbsup: Looks like ill get one or two more quarts just to be safe. Thanks agian.
Are you going to use Dex-III or the better, Dex-VI ?
Im going to be adding in Amsoil ATF, i did a filter change on my Alero and used Amsoil ATF in that, shifts way smoother now. Hopefully it smooths out my Envoy, seems to shift little weird?
Deep pan has a step and shallow is straight across.
2004 gmc envoy_sle_xl
The easy way is to just buy both filters for the shallow pan and the deep pan. Then take back the filter you don't use. Make a note in the owners manual which filter you need and the next time you'll be ready. I know it is a pain to go back to the part store, but it is a bigger pain to go back while the pan is off and wind may be bloing dirt around.
what do you guys recommend if I do a pan drop/filter change,; mobil 1 for dex III or use a dex VI product in a 04 TB? not sure if I have an amsoil dealer around.
thanks
I use the DEX-VI and think the tranny is smoother. I also added a +2 qt. Hughes tranny pan, finned alum with a drain plug.
I bought my Amsoil online, purchased the perferred membership and get oil at dealer cost. buying a $10 membership saved me over $75 on my final purchase. Good deal :thumbsup:
:hijackedNot to thread steal or anything but why did GM use 2 different depth pans. Was it a model year change?:eek:fftopic:
That would be my guess.. but it was very early on.. so the early to late 2002's have the shallow pan.. as mines an 03 and has the deep pan
2007 gmc
2wd typically have the shallow pan (~2-1/8" depth) and 4wd typically have the deep pan (~2-7/8"). Some of the 2wds with towing or cruise packages may have the deeper pan. The deeper pans sometimes will have a inch or so drop towards the rear of the pan.
1 - 20 of 20 Posts
