04 LS, 4.2 L6 with 360k miles.
Hoping to find some help with the connector on the return side of the radiator. Not because I'm modifying anything, but because it has recently developed a slow leak. Not leaking where it threads in, but where the line snaps into the connector, so pretty sure it's the o-ring.
Either way, needs replaced. Rockauto actually lists two different part #s for the cooler line, radiator side, so tried them both. Part #800-619 (looks a lot like part #15226661, I saw in another discussion)---too small (9/16= ~14mm?). Doesn't even make contact with the threads. Tried the 800-721 (18mm)---too big. Finally hit me to put that connector on a thread-checker. Definitely a 16mm..
Even went as far as trying an old connector, sitting in a 03 LaCrosse radiator I helped a neighbor change about a month ago. Close, but no cigar.
Probably too much info, all to say I'm stumped. Really could use some help/ideas on how to track down the right part.
