I have a 2006 Ascender 4wd. 6 Cylinder. I hear a whine in the transmission when in neutral the car shifts fine . Any Ideas? Thank you
If this is really in the transmission... in neutral, you're hearing your front pump blades.
It COULD be a broken pump ring... that would be a short trip though... aluminum being shredded and being pumped through the unit.... bad news!
It COULD be a partially plugged or badly installed filter..... or broken/missing seal on end of filter pickup tube
It COULD be low on fluid......
The pump might be in full flow-pressure position, being told to go there because of a modified ECM.
If you don't want to drop the pan to check the filter situation and for debris, at least run a line pressure test.
