1 - 3 of 3 Posts
Help!!! I have an 05 ls 4x4. It won't shift out of second gear. I had the code checked, it said low level or contaminated fluid. I discovered a leak in the cooler line, fixed that and changed the fluid. Still the same problem, but the code went away. What next?
Welcome to the site. It shifts from 1 to 2 and then no more shifts? Sorry to say this but you might be in the market for a tranny swap or rebuild. :(
finally had the guts to take it on the highway. It revved to about 5000 rpm, I let off the gas and it shifted. I was able to maintain 60 mph, but it would downshift occasionally. If I let off the gas it would shift again. This is aggravating!
1 - 3 of 3 Posts
