1 - 20 of 77 Posts
2006 chevy
A TrailVoy Exclusive ;) The First SS recieved the first of many aftermarket calibration adjustments to the E40 ECU today. This is a joint effort between my company (White Automotive & Media Services) and Vector Motorsports, a VERY well known tuner in the Metro Detroit area that has lots of high profile shops for clients ;)
Here is a quick rundown of what was changed today:
Top Speed Limiter (Stock 130) Removed
High Octane Spark Table Tweaked for Low RPM and overall performance
Power Enrichment Mode Enable Lowered
Axle Torque Limiters Removed (Maxed Out)
Launch Control timing retard removed
All other engine related torque/abuse mode management removed (includes torque reduction per gear by RPM)
This product is still in beta and once we get to work on the Transmission Control Module (TCM) the gains will be incredible. This truck really can benefit from some slightly higher shift points as well as higher line pressure and lower commanded shift times.
So how does it work you ask? Well those of you who said your trucks were pretty dead below 3000 will be astounded, there is no longer any throttle lag and it launches and accelerates considerably harder. Final HP and ET reductions will be announced after we hit the dyno and do a complete tune rather than just a road tune. All I can tell you is stock the truck hit another 5.3 0-60 and ran a [email protected] with a passenger and a half a tank of gas and it's CONSIDERABLY quicker now.
The good news for you guys is this calibration (and TCM calibration when completed) will be available to TrailVoy members exclusively for $399 (you must ship in your ECM/TCM) with a same day turn around service!
Other fun things we learned today:
1. Torque management sucks :)
2. My AWD SS weighs in at 4875lbs with 3/4 of a tank
3. AWD launches with TM removed are even more fun :)
Keep an eye on this section for updates and other new products for your TBSS (and 5.3L Trail/Voy ;))
Northwest Chapter
Very nice, but what about the I6 engine? I doubt you have time to tune them as well, but that is great to hear about the SS tunes, as if I ever get an SS it will receive one ASAP.
2006 chevy
Is that 4875 with you in the vehicle, or just wet curb weight with 3/4 of a tank (how big is the gas tank again)?
Cool stuff, can't wait to see what you are able to wring out of the LS2. :yes:
You've known this for a long time. Not new news to you. :D
I presume the Rainier would also qualify for a reprogram on the 5.3L. Not like I have one. I'd like one, considering they are on the chopping block after '07.
2006 chevy trailblazer_ss_lt
Fishhunter911 said:
Hey guys... This was done on an SS it has a 6.0L not a 5.3L Although he may be able to hook you guys up as well......
GTPprix said:
Keep an eye on this section for updates and other new products for your TBSS (and 5.3L Trail/Voy )
bout time the v8'ers got some love...
Hurry my SS is Super Slow...:laugh:
2006 chevy trailblazer_ss_ls
are those time the AWD version?
2006 chevy
Discussion Starter #18
Wow ok time to answer questions :)
1. Yes that 4875lbs was just the truck with 3/4 of a tank. It did also have my Tech 2 in it and an Innovate Wideband as well as some other things but I doubt they added more than 25lbs or so.
2. As far as impact to fuel economy, depending on how the final tune is setup there likely wont be any negative impact whatsoever. However with the amount of timing that we have been able to add so far (assuming it works to our advantage on the dyno) there may actually be a slight improvement ;)
3.SCCA yeah I knew TM sucks ;)
4. Yes those times were for the AWD version, so far it seems the 2WD (at least in other testing) seems to be considerably slower out of the box.
5. I will post the final numbers from the dyno as soon as the testing/tuning is completed. There may not be a HUGE gain in horsepower or torque on paper as the factory calibration is relatively decent. However the big thing here will be the performance increase from the removal of all the nanny controls and the increase in consistency in various temperatures :)
2006 chevy
Discussion Starter #19
Oh I forgot the most important fun fact, after the beta cal I can now spin the front tires with ease on a 1500+ RPM powerbrake launch ;)
1 - 20 of 77 Posts
