1 - 8 of 8 Posts
Some of the bulbs in my instrument panel are going bad can I buy full 10 pack of led bulbs that just pop in and be good to go?
YouTube is saying you have to solder in but I found a kit on ebay that just pops in place and good to go any input is very helpful
2008 chevy trailblazer_lt
Before I bought leds I removed my panel on my 08 tb and the lights were soldered on. No twist lock bulbs. I probed and found all grounds and marked them. I bought the led kit that has the resistor on the led. I bent the legs to match the height of the factory lights and soldered them on. It's awesome.
So cant just buy the kit that pops in I would have to solder the new ones in?
It would be a good idea to see which
type bulbs you have before buying or look on youtube for your year,model to
see which ones it has. That's how I knew mine soldered on.
If they are soldered in, first you have to remove the old ones.
Heres a few tips from someone who has done a few boards already......l
40 Watt soldering pencil
Solder sucker or
Solder Wick... (not as effective)
Make sure of the polarity of the board.
The longest legs on the LEDs are +
Maintain the correct height of the new LEDs.
Make sure to buy DIMMABLE LEDs
Keep your fingers off the clear plastic... it scratches easily.
Discussion Starter #8
Question I found a gauge cluster from a gmc envoy for $30 would that fit with the plugs in my trailblazer?
1 - 8 of 8 Posts
