1 - 8 of 8 Posts
So i was just taking a ride in the woods over the weekend and came across a puddle that was deeper than expected and water came in from under the door how can i prevent this from happening. Pictures to come once i figure it out.
Most I've taken in on a long 20-22" deep water crossing was about a gallon. Need to double up on the door seals to do better, or else do the door seal stiffness mod (look for that article.)
More than that - the traditional trick is to get out, seal all the lower parts of the door cracks with painter's masking tape BEFORE the trail run, and climb in through the window or the back hatch to drive.
Or live with it as part of the post-run clean-up.
If a little water bothers you too much, it's not the VEHICLE whose trail rating you should be worrying about. :thumbsup:
Northeast Chapter
2004
lift kit, 32" tires.......we went through a LOT of water (river crossing) at TECORE and I saw none inside my truck.....nobody else did either. Search "tecore" and check out the vids and pictures....water over headlights, and not a drop on the inside...:undecided
1 - 8 of 8 Posts
