1 - 14 of 14 Posts
Are you talking about a tire pressure monitoring system? If so, my guess would be that you cannot disable it since it's a safety issue.
I could be wrong, but I think some of the systems dont actually use pressure monitors, but instead it measures the revolutions of the wheel and based on that the system can calculate if the air pressure is within an acceptable range.
I think I remember reading this in Motor Trend a while ago...:undecided
EDIT: Ok so I was right, there is one system that works as mentioned above, not sure if GM uses it. Obviously any aftermarket rims that are large than stock will cause the system to read incorrectly.
http://www.motortrend.com/features/car_care/112_0401_winter_tire_maintenance/pressure_monitors_inflation.html
Discussion Starter #7
the sensors for the ss mount in the rim in place off the valve stem. i can mount them in my rims but it doesnt allow for very much tire deflection. if tire hits sensor it will most likely brake and end with a flat.
2005 isuzu ascender
if its the same system that was in my Isuzu Rodeo (all of its electronics were from GM/Delphi) and it was a total CF :) one of the worst systems I have seen in a while.
when did our trailvoy's come with this option?
I know the TBSS has it but I'm not sure about the other TVs.
My LT does not have it but my Prowler does.
If its just an idiot light that goes on for the tire pressure being low or that its not getting a signal from the pressure monitors, just disable the light in the dash.
1 - 14 of 14 Posts
