Gents:
I am curious as to which temps effect timing?
Is it just IAT temps or coolant temps?
Thanks!
2007 gmc
From what I can remember:
Stabilitrak
Torque Management (Engine and Transmission)
IAT
ECT
Speed limiter
These will all pull timing unless you play with the parameters to tell them to do otherwise... One thing I like using is adding or subtracting degrees from the IAT table, no way you'd get pinging and knocking in hot weather again... and inthe cold, I've added at least 3*s of timing!
