No --- to qualify for hints, you need to post 33 goofy answers first.
Just 33? Here goes:
33. Blocker for harmful UHF frequencies.
32. Block heater recirculation.
31. Chain dampener.
30. CB antenna relay.
29. Chain cleaner and degreaser.
28. Secondary timing chain guide.
27. Extra iron for the oil.
26. Magnetic timing chain alignment tool.
25. Counterweight for the cylinder head.
24. Camshaft position sensor recalibration aid.
23. Crankshaft position sensor recalibration aid.
22. Oil pan support metal.
21. Skid plate for the factory robot.
20. Practice weld for the apprentice.
19. Bottom access hatch for the timing chain.
18. Knife sharpener.
17. Magnet to remove debris from the drive belt as it passes.
16. Bullet proof armor.
15. Heat sink.
14. Orientation guide for installation.
13. Poor man's "this side in" sign.
12. You can keep notes on it.
11. Magnet point for putting your kids artwork/high test grade/high project grade on.
10. Seal for some random California compliance device that was removed once the car left California.
09. Harmonic loudener.
08. Wheel alignment calibration marks.
07. Leveling plate to add just a bit more weight to the front.
06. Old nameplate from previous generation model
05. Tracking pad.
04. Wireless battery charger.
03. Spoiler alter! It's plastic!
02. Badge from the boat captain.
01. Leftover from when vehicles had to be started using a hand crank.
There you go. 33 goofy answers.
