1 - 14 of 14 Posts
02 ls i6
I was wondering if anyone has experienced any ticking noises after the engine has warmed up. My sounds fine on start up, but after driving for 10-15 min it has a ticking sound while at idle. I've had the exhaust manifold tsb performed and fan clutch replaced and it still ticks
2007 gmc
if u feel its coming internally from the engine, then I'd say it was the hydraulic rockers... i think the only cure would be to install a new head onto our I6... might be doing that soon if i get the money, with a small p&p job :p
Discussion Starter #6
Does the computer have to be reprogrammed after replacing the fan clutch. I replace the fan clutch myself. Purchased from local dealership.
2002 chevy trailblazer_lt_ext
ticking noise ?
I have beening hearing a chirp/ticking noise for a year. 02, 4.2 TB. I thought it was the exhaust manifold. I just observed a crack on a plate on the exhaust side of the head. I see the exhaust soot. I haven't indentied the part yet. I was quite faint in the begining and I not so noticeable when the engine is warm.
I have a similar sounding issue with my 03 I6. Ticking only when the motor is warm. Fan clutch has been replaced. The ticking sounds like it is coming from inside of the top side of engine. My mechanic said to put in Lucus oil conditioner; I did but no improvement.
He says that opening up that engine is expensive. It sounds kind of getto but does not seem to be getting worse.
Did you get anywhere with you issue?
clipping noise
I changed out the plate and gasket, problem solved. The plate had been over tigthen when the transmission fill tube was removed by the dealer.
'05 I6 tick
I just started getting a tick seamingly coming from the top of my front cylinder, only at idle. I believe it's going to be a rocker and I hear it now only because I used to use conventional 10w-30 and now I'm using synthetic 5w-30.
Does anyone know how long this will go before needing major repairs or if it's even a significant issue?:undecided
I have a very similar sounding issue with my son's 03 I6. The tick can only be heard at idle and after the engine is warm. 2 mechanics both said not to worry about it that opening the engine was not an option at this point. They both suggested adding an oil conditioner, which I did without an improvement.
Did you get the noise to stop? I'd be willing to change to another oil if I thought it would. It sounds a little ghetto and I doubt I could sell the car with that noise.
I have the similar ticking. Mine is more when accelerating after engine is warm, fairly quick ticking. Almost like a poker card in the wheel of a bicycle. I do have the slower ticking noise when TB I6 is just started which I hear is normal and goes away once the engine is warm. My ticking when warm on acceleration does not seem as loud as the engine warming up ticking noise. Please help as I can not afford to put any more money out on this 03 TB. Thank you
Me too....loud ticking and also little tick at start up coming from the top and front of the engine. So here's what I just went through 2 weeks ago. In many cases the ticking is actually the bearing in the alternator many have found this to be an issue. If you rotate the pulley with the belt off and you feel a little resistance it's that bearing. My O2 Trailblazer has 220k miles on it so here's what I did recently I left my totally incompetent mechanic after 40 years and went to another who turned out to be outstanding the manifold was cracked he replaced that and the clunking noise is gone as all the shocks we replaced. Prior to doing that, I replaced the tensioner pulley the VVT solenoid the cam solenoid and the black belt pulley I found these on Amazon as their less expensive t h a n RockAuto with delivery. Everything sounds great now. Also in both cases I remove the positive cable from the battery for reset. Originally no codes were noted of significance. The next thing I did since the loud tick was gone the little baby tick sort of comes and goes I know it's the hydraulic lifter but still the car just still didn't feel like it had a vibe. I tested all the coils as one has been replaced many years ago all of them were AC Delco brand. Even though the car was running great after being at the mechanics I decided as I found out a little trick you never replace just one coil when they go bad you replace all of them so I figured I'd give that a try I went back on the Amazon and bought the qyl brand even at $20 a piece everyone I thought they were outstanding. I will let everyone know here they are superb coils. They are a steal and they are superb quality I actually think they're better than OEM manufacturer and I also got the tip no pun intended to buy the AC Delco iridium spark plugs which are already Gap from the factory you don't touch them. I put the new plugs and coils in place. My freaking 02 TrailBlazer, get this is running better than it did new with 220k on it the idle is smooth as silk the power is fantastic no rough idle it's just crazy. No back to the baby little tick I have it at startup. So here's my next change, some research has indicated and suggested that I use only the AC Delco oil filters. Rumor Has It that a number of aftermarket filters actually have more restrictive filter elements inside. Thus upon startup the oil Journal in the front of the engine are the last ones to receive oil. So at Walmart they have the original filters I bought two I'm actually going to do my old gear head trick. With 220k miles on the vehicle and only running synthetics since new Mobil 1 in this case. I'm going to use the original Factory filter I'm going to try 10- 40. I live in Maryland so it gets pretty hot around here in summertime. Some people have said this calm down the baby tick so give it a try and report back. Also you can always try the additive dose of Marvel Mystery Oil that really seems to clean and unstick everything inside but when I drain the oil out it's really good looking and no gunk is that so what I wouldn't expect based upon how it taken care of the car. I apologize for such a long response I was just trying to impart my experience. Believe me it was all driving me nuts just ask my wife. I've not been here in a long time but this is actually a superb site with superb people on it. I bought my new from the dealer if Gertrude continues another 4 years that'll be great. So far so good I will repost the results after this next oil change for everyone. God bless all of you and have a great day thank you for reading.
1 - 14 of 14 Posts
