Okay, folks I got to page 25 and said enough. I have a 2006 TB I bought used. Tonight the TB would not start after running fine for two years. It has little over 60k miles. The error codes I have received is the front and rear O2 sensor heating circuits failed and the traditional fuel gauge problem. It seems quite odd that I have both these codes at the same time the TB turns over but won't start. The check engine light has been coming on and going off by itself for the last week and half. O2 codes are p0135 and p0141. The vehicle did stall once this week. Also, I have seen an intermittent exhaust crankshaft position sensor errors well. Thought I may have caused the problem when I replaced the Idler pulley. The crankshaft position sensor error happened right the replacement.
The main thing I like would to do is a simple fix so as to get it running and get it home.
With this information I need to know if it is the starter switch, the fuel pump, or the O2 sensors that is causing the engine to turn over but will not start.
HELP!
HELP!
