So today I found out none of my tail lights work in my 07 TBSS. Left, right, and 3rd are all out. But my blinker, parking lights, and reverse lights work fine.... So I started with the basics. Checked ALL the fuses under the hood and under the rear seat that pertained to the rear lights and 3rd brake light. All were good and not blown.
Next, I checked the bulbs. All bulbs the were good. I even swapped the good blinker bulbs in the 2nd slot with to the top, no luck.
Then I checked the switch on the brake pedal. Not too sure what exactly I was looking for so I measured the voltages at the brake light fuse slots on the fuse panels. Pulled the fuse, attached a DVM meter to the open pin slots, had someone hit the brakes, and had the tone go off showing the circuit was working. So it shows me the switch at the pedal is good.
To me it seems there may be a cut in a wire or something. If it was grounded out, I'd think I'd lose a fuse. Does anyone know how the wiring works from the fuse panel --> the rear lights? Is there a bridge somewhere for the 3 lights?
And just so everyone knows, Im not a newbie... I did a search and came up with this thread. This is the closest to my situation. http://forums.trailvoy.com/showthread.php?t=53234" Any help would be appreciated. Thanks all!
