1 - 20 of 34 Posts
2003 trailblazer_lt
What's good everybody? I'm fixing to get some prices of specific repairs from those who have taken their I6 tb/envoy in for these services/repairs. It doesn't matter if it was the dealer or an independent shop.
In case you're thinking "hey brah, why don't you call some shops yourself ya bum!!"....well, the upfront estimate is usually just that - an estimate. I want the total cost, down to the "shop supplies" or "hazmat fees" or "doorbell ringing fees."
So, if you've had any of these repairs done by a shop, chime on in!:cool:
Spark plug replacement
Throttle body cleaning
Thermostat replacement
Front brake pads and both front rotors replacement
Rear brake pads and both rear rotors replacement
Serpentine belt/tensioner/idler replacement
Headlight connector repair
Sway bar links/bushings (front/rear)
Blower resistor replaced and new connector installed
Cluster replace and program
Any module flash (pcm, bcm, etc)
CASE relearn
Front struts replaced
Ball joints (upper and lower)
7 quart oil change, tire rotate, and brake inspection
:thx
2006 chevy trailblazer_lt_ext
yes, you should be able to do most of them yourself, just replaced my idler for 30 bucks and it only took me a few min. you can find a ton of info on here if you search, there is a wealth of knowlege here. :woot:
$25 for case relearn...I don't let others work on my truck but couldn't find a way to do that myself.
2003 trailblazer_lt
Discussion Starter #8
For most of your list just do a little reading here then get your hands dirty.
But I just had a manicure done.
CASE relearn 50.00
Thank you sir!
If only it were that easy!
In this thread:
http://forums.trailvoy.com/showthread.php?t=68136
We have estimates from $260 - $300 (US) and $360 (Canada) for spark plug replacement but no confirmed price of repair.
I got a BCM replaced after it died. Took it to the dealer since it was under warranty and it came out to about $250 with a warranty.
Thank you sir!
How much did that cost?:raspberry
Thank you sir! And I hear you, I have to have someone install a windshield and just the thought of another man touching my truck gets my nerves worked:mad:
Originally Posted by lint
edited
Sorry got called away on duty ... garbage take out ,couldn't finish :eek:
''pcm flash 65.00''
2003 trailblazer_lt
Discussion Starter #10 (Edited)
''pcm flash 65.00''
Thanks dude:cool:
I'm bolding things so it looks more filled in.
Spark plug replacement $90.00
Front brake pads and both front rotors replacement $340
Serpentine belt/tensioner/idler replacement $86.00
Headlight connector repair $90.00
Cluster replace and program program $60.00 replace $750
Any module flash (pcm, bcm, etc) $65.00
CASE relearn $25 - $50
7 quart oil change $27.00 - $38.00 oil and filter not synthetic
tire rotate varies $15-$25
brake inspection
7 quart oil change, tire rotate, and brake inspection $80 with Mobil 1 or $50 conventional
Wheel bearing replace $530
Spark plugs cost me 400$ but that was with the stealership taking out a snapped off one. Otherwise they said it would cost 90$ just to replace all 6
2003 trailblazer_lt
Discussion Starter #14
you planing on opening your own shop?
oil change - $27
sub install - priceless :D
Man you got the hookup on the oil changes, nobody around here is under $30 (up to 5 quarts):thumbsup:
Also, word:cool:
Getting a new cluster depends on where you get it. I had mine programmed at the dealership for $60.
Thanks man!
Was that parts and labor?:undecided
2005 saab 9_7x
Front brake pads and both front rotors replacement I paid $90 for my ceramic pads and installed them myself
Rear brake pads and both rear rotors replacement I paid $90 for my ceramic pads and installed them myself
Cluster replace and program was told about $750 from dealership
CASE relearn
I will add that I had a wheel bearing replaced under my extended warranty, it would have cost $530 parts and labor otherwise
Front ball joints, upper and lower is 110 bought from the parts store and installed yourself....Dont forget the idler pulley that we've all had to replace 25bucks,replaced at a shop. (if people havent replaced it yet,they will, it just a matter of time)
2003 trailblazer_lt
Discussion Starter #19
i've only paid for tire rotations. usually 20 bucks.
Thanks man!
Yeah that was parts and labor. Total with taxes was a dollar or two over 100$.
Awesome!
CASE relearn
Thanks dude, I KNEW I was forgetting something else that was a common thing...thanks for reminding me about them wheel bearings.
Thanks man!
1 - 20 of 34 Posts
