02 Envoy SLE
I've recently purchased an 02 Envoy from an auction.
There are a couple of issues.
The main one started last night. While at the store I put the truck in park and turn off the ignition. The ignition will not go into the lock position. I messed with the key and go it to turn off. Then started the truck to leave and couldn't put the truck in gear. I messed with the shifter and was able to put into gear. At that point the gear shifter would move from park to reverse without me pushing the break pedal. I drove home and could not turn the key all of the way off again. Moved gear selector from 1st to Park a few times and then was able to remove the key. I restarted the truck and could not move the gear selector again; however I was able to remove the key easily.
I am leaning towards replacing the "Neutral Safety Switch" on the tranny but with my symptoms, I've seen brake light switch, ignition, and solenoid at gear shift selection. I'm just looking for a bit more guidance before doing the work
Since I purchased the truck, I've replaced,
Battery
Ignition Coil
Cleaned Throttle Body (Thanks to this forum)
I found the plug yesterday when I removed the console. I messed around with the wires and moved them around a bit but didn't find any broken ones. While console was removed I messed with the shifter and the key and it seemed to work both shifter and key were working fine. I put the console back together and started having the issue again.
I did figure out that if the key is stuck, if I tap the brakes while in park and turn the key back, I am able to turn off the truck.
I believe the problem is in the wiring at the brake switch connected to the brake pedal. I messed around with those wires and pushed them allow the way back into the plug and all has bee good since. I'll continue to monitor and post back.
Thanks,
2005 chevy trailblazer_ls_ext
similar problems last night
Check the ground under the passenger side of the console. I had a similar issue but couldn't get a temporary solution like yours. If the ground is intermittent it could explain why you are up and running now, but could you get stranded. And its a 5 minute and free fix if that's the problem.
http://forums.trailvoy.com/showthread.php?t=97874
