1 - 7 of 7 Posts
Hi Everyone ,
My 06 TB just started stalling after the initial start up in the morning. It would sit for a good 12hrs at night and when I start it it will run and then stall out. I can re-start it right back up and leave for work and the truck is fine the rest of the day. It has happend about 3 times in the last two weeks. Any ideas ? ... No check engine lights or anything , the rpm will idle at 500-600.
Thanks !!
Maybe a leaky fuel injector? Try some good fuel injector cleaner.
Ok so I went to Autozone today and the code is P0014 ? .... any ideas ... The guy at autozone said the first thing I should try is to do a oil and filter change because the code for cam shaft stuff ..... any help would be greatly appreciated .... is the truck safe to drive still ?
The truck is safe to drive. Usually an oil and filter change will fix it. Has it been a long time since the oil was changed?
1 - 7 of 7 Posts
