hello all.... I have a 2003 TB and recently have been hearing a squeak from underneath when moving forward. I checked the front drive shaft and when wiggling back and forth near the transfer case it had play in it. I removed the shaft and still have the squeak when spinning the rear wheels while on jackstands. The noise is coming from the front of the transfer case. I have read posts on other websites that say its a u-joint on the rear drive shaft that is resonating to the front of the transfer case. the other posts say there is nothing in the transfer case that should cause squeaking. truck has 133k and I changed the transfer case fluid at 100k. thanks for any info !!!
Hello. Did you find problem. Sounds like I have the same sound on my 2 WD. Squeaks when I rotate driveshaft from just ahead of front u-joint. Maybe in transmission?
