1 - 20 of 22 Posts
http://www.mattracks.com
they say they will work on most 4x4 vehicles.
im sure that would open up some opprotunities,and you wouldnt need a spare track cuz they wont go flat
i know they arent cheap...
i have no chance of getting them,but what do you all have to say about them?
looks like alot of possibilities could open up in snow mud and sand for us...
· Northeast Chapter
2004
I personally think they'd create too much of a headache. I'm sure there are a lot of maintenance items that go along with those things. I wouldn't do it even if I had the money. There are much better ways to spend $4K, IMO.......:m2:
alright so i got ahold of them today via phone and they said the model 88's would for sure fit,probably even without any body lifts.
prices they said were 2100 for the solid suspension
and i forget the exact,but somewhere between 2400 and 2500 for the independent.
NOTE:
i do not remember if that was the pricing for a set or for all four.
but here is the copy of an email i JUST got from them
but it just sent me pdf copies of the 88 series.
and yeah this is what i got in the text portion of the email
Hi Tyler:
Thank you for your interest in Mattracks. Attached are the spec sheets for the 88 series of tracks and pricing, which will fit your mentioned vehicle. I will contact you next week to follow up and answer any questions.
Jon
This communication may contain privileged and/or confidential information. It is intended solely for the use of the addressee. If you are not the intended recipient, you are strictly prohibited from disclosing, copying, distributing or using any of this information. If you received this communication in error, please contact the sender immediately and destroy the material in its entirety, whether electronic or hard copy. You may not directly or indirectly reuse or redisclose such information for any purpose other than to provide the services for which you are receiving the information.
Jon Bohm
MATTRACKS® Incorporated
202 Cleveland Avenue East
Karlstad, MN 56732
Phone 218-436-7000
Fax 218-436-7500
www.mattracks.com
www.litefootatv.com
Well, I would start buying stock in whoever makes the power steering pump for our vehicles... The extra load from the tracks will certainly take out the pump. I've driven these on a 4-wheeler, and boy did the steering require alot more force than just the tires, as in non exsistent at stand still and an arm builder once in motion.
You may have to check your local laws about using them on the streets. Some cities/states have regulations against them being used on road and off road alike.
However, if you offroad a great deal, these would certainly be a nice Tread Lightly modification. As previously mentioned, a solid axle swap would be a good idea with a hydralic ram assisted steering added to the vehicle to make it more enjoyable to drive.
speaking of power steering...mine went out on me the other day
Are you actually interested in purchasing these, or are you just leading the company on for no reason?
If you are actually planning to purchase this, why? What is your mission for your vehicle? And don't say you want it to look cool. The only true reasons to have this type of equipment is for overland use in extreme snow conditions or for travel over sensitive environments, where low ground pressure is a must.
The prior poster is also quite correct with their assumption that our power steering would have an issue. The scrub radius on the extreme corners of the pads are immense. With a regular tire, it just spins as you turn it (when parked), however the tracks must be dragged across the ground. Not for pavement use.
Discussion Starter · #18 ·
my mother put the thing into a ditch monday avoiding a whitetail,and its been draining through steering fluid since.
i spend practically all winter in michigans UP.
where theres more unplowed roads than not.
and alot of it is spent on 2 tracks and wilderness trails
just looking for alternatives to snowmobiles and 4WD quads
snow tires and snow chains arent cutting it very well in deeper snow.
(i know tracks wont put it totally on top of the snow...but it'd put it up higher)
i told the guy that im not 100% on what we'd like to do yet via phone.
1 - 20 of 22 Posts
