1 - 3 of 3 Posts
I have the same issue to the issue below this one that palafoja posted. I have replaced the Low Pressure Cycling Switch and I am still having issues. If I drive my vehicle for an hour or so plus my a/c will stop working. It will work fine if it I turn my vehicle off for 5 or 10 minutes. The compressor seems to kicks off completely. It works fine up until this point. The low pressure reads fine while running and fine while at idol. What else might this issue be?
http://forums.trailvoy.com/showthread.php?t=87592
The compressor's magnetic clutch or internal overtemp switch could be bad. Member "c good" had the clutch issue, and it took a long time to troubleshoot.
Hey Roadie,
I appreciate all the Help on both forums. I will try replacing that! I will do it later on this week and be sure to post an update! Thanks again for the help!
Jon,
1 - 3 of 3 Posts
