1 - 10 of 10 Posts
I have been using this forum for a while with great success so thanks to all but now I have a question.
My 2005 Trailblazer ext with 158k miles has a transmission problem. Reverse is good and it takes off as usual through 1st and 2nd then when it should go into 3rd it just revs, if I let it get to around 4K and back off the throttle it goes into 3rd but never into 4th. Would it be the shift solenoids (which I could probably change myself) or bad 3/4 clutch (which I would take into a shop to be rebuilt). If it needs to be rebuilt how long can I continue to drive it while I get the money together to get it rebuilt (I am currently only using it around town where I don’t need to go into 4th - I have probably done 300 miles like this already and what will be the next sign(if any) that total transmission breakdown is imminent?
It could last years or break tomorrow. You should be fine around town as long as you don’t beat it. You could also just get those clutches replaced fairly responsible but while they are in there it’s kind of a nobranner. Also look at used transmissions
3-4 clutch failure won't set a code.
miketexas mine didn't throw a code but lost 3 and 4. replaced fluid, gasket, filter and solenoid B. tested solenoid A and it seemed to work. now it takes off fine but when shifts it revs and I can't go faster than 10 maybe 15 mph. what initiated problem was line blew out of radiator shooting fluid out over the hwy. someone did not put line back in right after radiator swap. Needless to say I work on my own vehicle now.
It needs to be rebuilt.
Yeah this just happened to my car. Its the 3/4 Clutch that need to be replaced. It costs me 2,500 to do it so i'm gonna have to just put the old trailblazer to sleep. I do plan to look into it by buying replacement parts or try to swap the transmission entirely.
· Premium Member
'05 TB 4.2 EXT
............... and another Zombie is resurrected.
1 - 10 of 10 Posts
